주요 콘텐츠로 건너뛰기
Lenovo ThinkPad Yoga Fan Replacement
필요한 것
  1. Lenovo ThinkPad Yoga Fan Replacement, Battery: 1 단계, 이미지 1/3 Lenovo ThinkPad Yoga Fan Replacement, Battery: 1 단계, 이미지 2/3 Lenovo ThinkPad Yoga Fan Replacement, Battery: 1 단계, 이미지 3/3
    • Flip the laptop over so the bottom is facing you.
    • Remove the ten screws using a Phillips #1 screwdriver.
    • Using the plastic opening tool, pry the bottom cover off the laptop.
  2. Lenovo ThinkPad Yoga Fan Replacement: 2 단계, 이미지 1/3 Lenovo ThinkPad Yoga Fan Replacement: 2 단계, 이미지 2/3 Lenovo ThinkPad Yoga Fan Replacement: 2 단계, 이미지 3/3
    • Remove two screws from the battery using a Phillips #1 screwdriver.
    • Disconnect the battery connector from the motherboard.
    • Remove the battery from the laptop.
  3. Lenovo ThinkPad Yoga Fan Replacement, Speakers: 3 단계, 이미지 1/3 Lenovo ThinkPad Yoga Fan Replacement, Speakers: 3 단계, 이미지 2/3 Lenovo ThinkPad Yoga Fan Replacement, Speakers: 3 단계, 이미지 3/3
    • Disconnect connectors. Use fingers to pinch and pull the connector out.
  4. Lenovo ThinkPad Yoga Fan Replacement, Fan: 4 단계, 이미지 1/3 Lenovo ThinkPad Yoga Fan Replacement, Fan: 4 단계, 이미지 2/3 Lenovo ThinkPad Yoga Fan Replacement, Fan: 4 단계, 이미지 3/3
    • Remove the two screws from the retainer for the ports using a Phillips #1 screwdriver.
    • Remove the nine screws from the motherboard using a Phillips #1 screwdriver.
    • Remove the four screws from the fan under the motherboard using a Phillips #1 screwdriver.
    • Remove the fan from the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Craig
회원 가입일: 10/28/21
217 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 4-4, Gulbrandsen Fall 2021 UMass Dartmouth, Team 4-4, Gulbrandsen Fall 2021 회원
UMASSD-GULBRANDSEN-F21S4G4
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 9
30일 전: 17
전체 시간: 439
