주요 콘텐츠로 건너뛰기
Lenovo ThinkPad Yoga Hard Drive Replacement
필요한 것
  1. Lenovo ThinkPad Yoga Hard Drive Replacement, Battery: 1 단계, 이미지 1/3 Lenovo ThinkPad Yoga Hard Drive Replacement, Battery: 1 단계, 이미지 2/3 Lenovo ThinkPad Yoga Hard Drive Replacement, Battery: 1 단계, 이미지 3/3
    • Flip the laptop over so the bottom is facing you.
    • Remove the ten screws using a Phillips #1 screwdriver.
    • Using the plastic opening tool, pry the bottom cover off the laptop.
  2. Lenovo ThinkPad Yoga Hard Drive Replacement: 2 단계, 이미지 1/3 Lenovo ThinkPad Yoga Hard Drive Replacement: 2 단계, 이미지 2/3 Lenovo ThinkPad Yoga Hard Drive Replacement: 2 단계, 이미지 3/3
    • Remove two screws from the battery using a Phillips #1 screwdriver.
    • Disconnect the battery connector from the motherboard.
    • Remove the battery from the laptop.
  3. Lenovo ThinkPad Yoga Hard Drive Replacement, Hard Drive: 3 단계, 이미지 1/2 Lenovo ThinkPad Yoga Hard Drive Replacement, Hard Drive: 3 단계, 이미지 2/2
    • Remove two screws using a Phillips #1 screwdriver.
    • Pull the hard drive horizontally in the direction of where the battery was located.
결론
Kristen Gismondi
회원 가입일: 11/12/14
81,782 평판
안내서 200개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,817개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 35
30일 전: 198
전체 시간: 3,855
