주요 콘텐츠로 건너뛰기
Lenovo ThinkPad Yoga RAM Replacement
필요한 것
  1. Lenovo ThinkPad Yoga RAM Replacement, Battery: 1 단계, 이미지 1/3 Lenovo ThinkPad Yoga RAM Replacement, Battery: 1 단계, 이미지 2/3 Lenovo ThinkPad Yoga RAM Replacement, Battery: 1 단계, 이미지 3/3
    • Flip the laptop over so the bottom is facing you.
    • Remove the ten screws using a Phillips #1 screwdriver.
    • Using the plastic opening tool, pry the bottom cover off the laptop.
  2. Lenovo ThinkPad Yoga RAM Replacement: 2 단계, 이미지 1/3 Lenovo ThinkPad Yoga RAM Replacement: 2 단계, 이미지 2/3 Lenovo ThinkPad Yoga RAM Replacement: 2 단계, 이미지 3/3
    • Remove two screws from the battery using a Phillips #1 screwdriver.
    • Disconnect the battery connector from the motherboard.
    • Remove the battery from the laptop.
  3. Lenovo ThinkPad Yoga RAM Replacement, RAM: 3 단계, 이미지 1/3 Lenovo ThinkPad Yoga RAM Replacement, RAM: 3 단계, 이미지 2/3 Lenovo ThinkPad Yoga RAM Replacement, RAM: 3 단계, 이미지 3/3
    • Remove nine screws from the motherboard with a Phillips #1 screwdriver.
    • Remove all ribbon cables attached to the motherboard.
    • Lift the motherboard out of the device.
  4. Lenovo ThinkPad Yoga RAM Replacement: 4 단계, 이미지 1/3 Lenovo ThinkPad Yoga RAM Replacement: 4 단계, 이미지 2/3 Lenovo ThinkPad Yoga RAM Replacement: 4 단계, 이미지 3/3
    • Desolder the RAM to replace it.
    • You may also opt to replace the entire motherboard if soldering is not an option.
결론
Michael Nessralla
회원 가입일: 10/28/21
171 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 4-4, Gulbrandsen Fall 2021 UMass Dartmouth, Team 4-4, Gulbrandsen Fall 2021 회원
UMASSD-GULBRANDSEN-F21S4G4
3 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 29
30일 전: 92
전체 시간: 1,334
