필요한 것
Flip the laptop over so the bottom is facing you.
Remove the ten screws using a Phillips #1 screwdriver.
Using the plastic opening tool, pry the bottom cover off the laptop.
Remove two screws under the plastic covers on the front of the screen using a Phillips #0 screwdriver.
Pry the plastic cover off with a spudger.
Remove the two screws from underneath the cover using a Phillips #0 screwdriver.
Detach the screen connector from the rest of the laptop.
거의 끝나갑니다!
결론
