주요 콘텐츠로 건너뛰기
Lenovo ThinkPad x120e Hard Drive Replacement
필요한 것
  1. Lenovo ThinkPad x120e Hard Drive Replacement, Battery: 1 단계, 이미지 1/2 Lenovo ThinkPad x120e Hard Drive Replacement, Battery: 1 단계, 이미지 2/2
    • Flip the laptop upside down and locate the battery latches under the battery.
    • Place your thumbs on both latches and push the latch inwards.
    • With your thumbs still on the latches, slide the battery out of the laptop.
    • To install a new battery, simply slide the battery back in the slot. Then, check if both battery latches are locked
  2. Lenovo ThinkPad x120e Hard Drive Replacement, Back Cover: 2 단계, 이미지 1/3 Lenovo ThinkPad x120e Hard Drive Replacement, Back Cover: 2 단계, 이미지 2/3 Lenovo ThinkPad x120e Hard Drive Replacement, Back Cover: 2 단계, 이미지 3/3
    • Using the Phillips #0 screwdriver, remove the three 4 mm screws that are securing the bottom cover.
    • Remove the backplate carefully, making sure not to bend the cover.
  3. Lenovo ThinkPad x120e Hard Drive Replacement, Hard Drive: 3 단계, 이미지 1/2 Lenovo ThinkPad x120e Hard Drive Replacement, Hard Drive: 3 단계, 이미지 2/2
    • Under the back cover, you'll find the drive bay containing the hard drive on the top left.
    • Using the Phillips #0 screwdriver, remove two 4 mm screws which are located on the top left and bottom right corners.
    • Slide out the hard drive from the back cover horrizontally.
    • The pictures only show the mount, not the actual hard drive. Unfortunately, the hard drive was lost during replacement.
  4. Lenovo ThinkPad x120e Hard Drive Replacement: 4 단계, 이미지 1/2 Lenovo ThinkPad x120e Hard Drive Replacement: 4 단계, 이미지 2/2
    • Using the same Phillips #0 screwdriver, remove the four 4 mm screws located on each side of the drive bay.
    • Remove the physical hard drive from the drive bay.
결론
Jacob Fronzaglia
회원 가입일: 10/25/21
787 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team 3-4, Sinclaire Fall 2021 UMass Dartmouth, Team 3-4, Sinclaire Fall 2021 회원
UMASSD-SINCLAIRE-F21S3G4
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 19
전체 시간: 250
