주요 콘텐츠로 건너뛰기
Lenovo ThinkPad x120e RAM Replacement
필요한 것
  1. Lenovo ThinkPad x120e RAM Replacement, Battery: 1 단계, 이미지 1/2 Lenovo ThinkPad x120e RAM Replacement, Battery: 1 단계, 이미지 2/2
    • Flip the laptop upside down and locate the battery latches under the battery.
    • Place your thumbs on both latches and push the latch inwards.
    • With your thumbs still on the latches, slide the battery out of the laptop.
    • To install a new battery, simply slide the battery back in the slot. Then, check if both battery latches are locked
  2. Lenovo ThinkPad x120e RAM Replacement, Back Cover: 2 단계, 이미지 1/3 Lenovo ThinkPad x120e RAM Replacement, Back Cover: 2 단계, 이미지 2/3 Lenovo ThinkPad x120e RAM Replacement, Back Cover: 2 단계, 이미지 3/3
    • Using the Phillips #0 screwdriver, remove the three 4 mm screws that are securing the bottom cover.
    • Remove the backplate carefully, making sure not to bend the cover.
  3. Lenovo ThinkPad x120e RAM Replacement, RAM: 3 단계, 이미지 1/3 Lenovo ThinkPad x120e RAM Replacement, RAM: 3 단계, 이미지 2/3 Lenovo ThinkPad x120e RAM Replacement, RAM: 3 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Anti-Static Wrist Strap
    $7.95
    구매
    • Push the two mounting clips on either side of the RAM away from each other.
    • While doing this step, wear an anti-static wrist strap. This will prevent you from generating static that could damage the RAM module.
  4. Lenovo ThinkPad x120e RAM Replacement: 4 단계, 이미지 1/2 Lenovo ThinkPad x120e RAM Replacement: 4 단계, 이미지 2/2
    • The RAM should now be lifting up at an angle.
    • Slide the RAM stick out in the direction the angle is facing.
    • While installing the new RAM stick, push the stick down at an angle and make sure you secure it with the small clips at both sides.
결론
Jacob Fronzaglia
회원 가입일: 10/25/21
787 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team 3-4, Sinclaire Fall 2021 UMass Dartmouth, Team 3-4, Sinclaire Fall 2021 회원
UMASSD-SINCLAIRE-F21S3G4
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 12
전체 시간: 325
