주요 콘텐츠로 건너뛰기
Lenovo Thinkpad E540 Fan Replacement
필요한 것
  1. Lenovo Thinkpad E540 Fan Replacement, Battery: 1 단계, 이미지 1/2 Lenovo Thinkpad E540 Fan Replacement, Battery: 1 단계, 이미지 2/2
    • Push the battery release switches away from each other.
  2. Lenovo Thinkpad E540 Fan Replacement: 2 단계, 이미지 1/1
    • Remove the battery.
  3. Lenovo Thinkpad E540 Fan Replacement, Disassembly of the Back Panel: 3 단계, 이미지 1/1
    • Remove the three 1.2mm Phillips #00 screws from the bottom panel.
  4. Lenovo Thinkpad E540 Fan Replacement: 4 단계, 이미지 1/1
    • Use a plastic opening tool to pry off the bottom panel.
  5. Lenovo Thinkpad E540 Fan Replacement, Fan: 5 단계, 이미지 1/1
    • Heatsink and fan are connected. You have to remove both at the same time.
    • The heatsink and fan are found on the right side.
  6. Lenovo Thinkpad E540 Fan Replacement: 6 단계, 이미지 1/1
    • Remove the two 1mm Phillips #0 screws from the fan.
    • Unscrew the four 2mm Phillips s#0 screws from the heatsink.
    • The screws on the heatsink will stay attached to it.
  7. Lenovo Thinkpad E540 Fan Replacement: 7 단계, 이미지 1/1
    • To remove the heatsink and fan, pull the fan upwards and towards the center.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Timothy Sumner
회원 가입일: 02/14/18
1,046 평판
안내서 8개 작성하였습니다
USF Tampa, Team S2-G5, Nance Spring 2018 USF Tampa, Team S2-G5, Nance Spring 2018 회원
USFT-NANCE-S18S2G5
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 9
30일 전: 25
전체 시간: 2,463
