주요 콘텐츠로 건너뛰기
Lenovo Thinkpad E540 Hard Drive Replacement
필요한 것
  1. Lenovo Thinkpad E540 Hard Drive Replacement, Battery: 1 단계, 이미지 1/2 Lenovo Thinkpad E540 Hard Drive Replacement, Battery: 1 단계, 이미지 2/2
    • Push the battery release switches away from each other.
  2. Lenovo Thinkpad E540 Hard Drive Replacement: 2 단계, 이미지 1/1
    • Remove the battery.
  3. Lenovo Thinkpad E540 Hard Drive Replacement, Disassembly of the Back Panel: 3 단계, 이미지 1/1
    • Remove the three 1.2mm Phillips #00 screws from the bottom panel.
    For me a Phillips #1 was the first bit with a tight fit (testet PH #00, #0, #1).
    Till - 답글
  4. Lenovo Thinkpad E540 Hard Drive Replacement: 4 단계, 이미지 1/1
    • Use a plastic opening tool to pry off the bottom panel.
  5. Lenovo Thinkpad E540 Hard Drive Replacement, Hard Drive: 5 단계, 이미지 1/1
    • Remove the four 1.2mm Phillips #0 screws from the hard drive.
  6. Lenovo Thinkpad E540 Hard Drive Replacement: 6 단계, 이미지 1/1
    • Pull up on the hard drive to allow for removal.
  7. Lenovo Thinkpad E540 Hard Drive Replacement: 7 단계, 이미지 1/1
    • Disconnect the hard drive and pull out to remove.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Timothy Sumner
회원 가입일: 02/14/18
1,040 평판
안내서 8개 작성하였습니다
USF Tampa, Team S2-G5, Nance Spring 2018 USF Tampa, Team S2-G5, Nance Spring 2018 회원
USFT-NANCE-S18S2G5
4 회원들
안내서 8개 작성하였습니다
댓글 한 개
Thanks for this invaluable and easy guide.
Is it possible to replace the hdd with an ssd for this model? If so, which ssd would fit this laptop’s hdd socket?
Many thanks in advance.
SKP - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 23
전체 시간: 5,361
