주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Lenovo Thinkpad E540 Keyboard Replacement
필요한 것
  1. Lenovo Thinkpad E540 Keyboard Replacement, Battery: 1 단계, 이미지 2개 중 1개 Lenovo Thinkpad E540 Keyboard Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Push the battery release switches away from each other.
  2. Lenovo Thinkpad E540 Keyboard Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the battery.
  3. Lenovo Thinkpad E540 Keyboard Replacement, Keyboard: 3 단계, 이미지 1개 중 1개
    • Push the keyboard forward towards the display to create a gap above the trackpad.
  4. Lenovo Thinkpad E540 Keyboard Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the four 1mm Phillips #00 screws found hidden underneath the keys.
  5. Lenovo Thinkpad E540 Keyboard Replacement: 5 단계, 이미지 1개 중 1개
    • Tilt the keyboard forward from the top and lift gently.
    • Dont pull too far because there is a cable attached to the back.
  6. Lenovo Thinkpad E540 Keyboard Replacement: 6 단계, 이미지 2개 중 1개 Lenovo Thinkpad E540 Keyboard Replacement: 6 단계, 이미지 2개 중 2개
    • Use a spudger to lift the black latch on the ZIF connectors.
    • Remove the blue and purple ribbon cables from the ZIF connectors.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Timothy Sumner
회원 가입일: 02/14/18
1,052 평판
안내서 8개를 작성함
USF Tampa, Team S2-G5, Nance Spring 2018 USF Tampa, Team S2-G5, Nance Spring 2018 회원
USFT-NANCE-S18S2G5
4 회원들
안내서 8개를 작성함
4가이드 댓글
Thank you for posting this guide. I was able to comfortably replace my keyboard on a Lenovo E540 Thinkpad after I spilled a full glass of water on it. I was able to get a replacement keyboard via AliExpress for $25.84USD -- I initially considered buying a replacement from eBay but the keyboard prices were half of the laptop's current value, which is a bit silly.
Thank you Timothy Sumner, you’re a legend! :)
Zeeshan Muhammad - 답글 공유
These instructions are miserably wrong for the model E540 20C6-008SUS. The keyboard is completely covered by a plastic grid that fills the large gaps between the keys. The keyboard hold-down screws are hidden by this grid. YOUR OWN PHOTO CLEARLY SHOWS THIS ! Furthermore, the keyboard can not be pushed “forward towards the display to create a gap above the trackpad “ simply because the 4 screws are holding it solidly in place. This plastic grid must be carefully pried up and out to expose the keyboard screws enough to be able to get a screwdriver in position over the screw heads.
Hewey Dewey - 답글 공유
With my edge 540 (submodel unknown) I was able to reach the screws by pushing the screw driver under the plastic grid. It did however slightly scuff up my F key
Dick van Zalinge - 답글 공유
You forgot the latch underneath the main battery.
Moose Technologies - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 19
지난 30일: 121
전체 시간: 11,754
