주요 콘텐츠로 건너뛰기
Lenovo Thinkpad E585 Hard Drive Replacement
필요한 것
  1. Lenovo Thinkpad E585 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/1
    • Remove the marked Screws.
    • Pry the backside of and put it aside.
  2. Lenovo Thinkpad E585 Hard Drive Replacement: 2 단계, 이미지 1/2 Lenovo Thinkpad E585 Hard Drive Replacement: 2 단계, 이미지 2/2
    • Pull gently on the marked pull tab. If it doesn't come out, pull harder.
    • After you pulled the Hard Drive Dummy out, remove the Connector.
  3. Lenovo Thinkpad E585 Hard Drive Replacement: 3 단계, 이미지 1/2 Lenovo Thinkpad E585 Hard Drive Replacement: 3 단계, 이미지 2/2
    • After the second step, you should have the dummy with the mounting hardware removed from the laptop.
    • Gently pull on the side until it comes off.
  4. Lenovo Thinkpad E585 Hard Drive Replacement: 4 단계, 이미지 1/1
    • Put your hard drive in the middle of the mounting hardware and align the sides with the holes on the hard drive. Make sure the pull tab is on the upside.
    • Push on it.
  5. Lenovo Thinkpad E585 Hard Drive Replacement: 5 단계, 이미지 1/1
    • Connect the connector.
    • Push on the ribbon cable to glue it to the underside.
  6. Lenovo Thinkpad E585 Hard Drive Replacement: 6 단계, 이미지 1/1
    • Finally, align the hard drive and push on the marked end.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Karl-Frederik Schlüter
회원 가입일: 12/24/20
290 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 25
전체 시간: 1,006
