주요 콘텐츠로 건너뛰기
Lenovo Thinkpad Edge E40 Hard Drive/SSD Replacement
필요한 것
  1. Lenovo Thinkpad Edge E40 Hard Drive/SSD Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Flip your laptop over.
    • Unplug all cables from the computer. If you're just swapping the battery, you can leave the power cord plugged in.
  2. Lenovo Thinkpad Edge E40 Hard Drive/SSD Replacement, Battery: 2 단계, 이미지 1개 중 1개
    • Pull the locking tab on the battery towards the unlock position.
    • Pull the battery out of the socket.
  3. Lenovo Thinkpad Edge E40 Hard Drive/SSD Replacement, Bottom Cover: 3 단계, 이미지 1개 중 1개
    • Loosen the following five screws:
    • 5 Phillips #0 screws
    • 1 recessed Phillips #0 screw
    • These screws do not come out all the way, and need to be un-tightened a lot more than you might think.
  4. Lenovo Thinkpad Edge E40 Hard Drive/SSD Replacement, Bottom Cover: 4 단계, 이미지 1개 중 1개
    • Pull up on the front cover from the left and right sides.
    • Do not force the cover off the laptop. If it does not want to come out, undo the screws a bit more.
  5. Lenovo Thinkpad Edge E40 Hard Drive/SSD Replacement, Hard Drive Caddy: 5 단계, 이미지 1개 중 1개
    • Slide the hard drive caddy to your left side using the pull tab.
    • Once it has been disconnected, pull up on the hard drive.
    • When reassembling, make sure to put the drive down before plugging it in. It might take some trial and error to get the drive seated properly.
  6. Lenovo Thinkpad Edge E40 Hard Drive/SSD Replacement: 6 단계, 이미지 1개 중 1개
    • Remove all the Phillips #0 screws from the outside of the hard drive caddy.
    • Do not remove any of the screws from the top or bottom of the hard drive, as doing so can cause irreparable damage to the hard drive and the data on it.
  7. Lenovo Thinkpad Edge E40 Hard Drive/SSD Replacement, Hard Drive: 7 단계, 이미지 1개 중 1개
    • Separate the hard drive and the caddy.
결론
Reinstall Windows or Linux on the new drive.
작성자
1다른 기여자 명과 함께
DistroHopper39B
회원 가입일: 05/30/20
414 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 22
전체 시간: 288
