주요 콘텐츠로 건너뛰기
Lenovo Thinkpad Edge E545 Fan Replacement
필요한 것
  1. Lenovo Thinkpad Edge E545 Fan Replacement, Battery: 1 단계, 이미지 1/1
    • First, flip the laptop over as shown in the photo.
    • Make sure device is fully powered down before removing battery.
  2. Lenovo Thinkpad Edge E545 Fan Replacement: 2 단계, 이미지 1/1
    • Below the battery are two small tabs. These function as a lock for the battery.
    • Push the tabs towards each other to release the battery.
  3. Lenovo Thinkpad Edge E545 Fan Replacement: 3 단계, 이미지 1/1
    • Remove the battery from the device.
  4. Lenovo Thinkpad Edge E545 Fan Replacement, Back Panel: 4 단계, 이미지 1/1
    • Using a Phillips screwdriver, remove the four screws around the edges of the rectangular panel.
    • It is recommend that you fully remove the screws and place them in a secure location.
    • Make sure to use the appropriate sized screwdriver. The wrong size can cause damage to the screws or screwdriver.
  5. Lenovo Thinkpad Edge E545 Fan Replacement: 5 단계, 이미지 1/2 Lenovo Thinkpad Edge E545 Fan Replacement: 5 단계, 이미지 2/2
    • Once all the screws are removed, gently slide the metal scalp around the edge of the panel to pry it open.
    • Slowly lift the left edge side of the panel with your fingers. Once the left side is up, continue lifting the right edge of the panel.
  6. Lenovo Thinkpad Edge E545 Fan Replacement: 6 단계, 이미지 1/1
    • Remove the back panel.
    • The back of the laptop will be exposed once the panel is removed.
    • Many of these small components are easily damaged--do not touch anything unless instructed to.
  7. Lenovo Thinkpad Edge E545 Fan Replacement, Fan: 7 단계, 이미지 1/1
    • Once the back panel is removed and the fan is accessible, remove the three 3 mm screws holding the fan in place using a Phillips #00 screwdriver.
  8. Lenovo Thinkpad Edge E545 Fan Replacement: 8 단계, 이미지 1/1
    • When the screws are removed, before the fan can be extracted, unplug the power connection to the fan by pulling it out of its socket.
    • With the screws removed and the power cable unplugged the fan can now be removed by lifting it out of its spot.
결론
John Metzger
회원 가입일: 12/03/18
190 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 9
전체 시간: 726
