메인 콘텐츠로 스킵하기
  1. First, flip the laptop over as shown in the photo.
    • First, flip the laptop over as shown in the photo.
    • Make sure device is fully powered down before removing battery.
  2. Below the battery are two small tabs. These function as a lock for the battery.
    • Below the battery are two small tabs. These function as a lock for the battery.
    • Push the tabs towards each other to release the battery.
  3. Remove the battery from the device.
    • Remove the battery from the device.
  4. 맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
    맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
  5. Using a Phillips screwdriver, remove the four screws around the edges of the  rectangular panel.
    • Using a Phillips screwdriver, remove the four screws around the edges of the rectangular panel.
    • It is recommend that you fully remove the screws and place them in a secure location.
    • Make sure to use the appropriate sized screwdriver. The wrong size can cause damage to the screws or screwdriver.
  6. Once all the screws are removed, gently slide the metal scalp around the edge of the panel to pry it open. Slowly lift the left edge side of the panel with your fingers.  Once the left side is up,  continue lifting the right edge of the panel.
    • Once all the screws are removed, gently slide the metal scalp around the edge of the panel to pry it open.
    • Slowly lift the left edge side of the panel with your fingers. Once the left side is up, continue lifting the right edge of the panel.
  7. Remove the back panel.
    • Remove the back panel.
    • The back of the laptop will be exposed once the panel is removed.
    • Many of these small components are easily damaged--do not touch anything unless instructed to.
  8. After back panel is removed, you can remove the two screws at the bottom of the hard drive using the Phillips #000 screwdriver. After back panel is removed, you can remove the two screws at the bottom of the hard drive using the Phillips #000 screwdriver.
    • After back panel is removed, you can remove the two screws at the bottom of the hard drive using the Phillips #000 screwdriver.
  9. After screws are removed, slide the hard drive down to disconnect from motherboard and remove it.
    • After screws are removed, slide the hard drive down to disconnect from motherboard and remove it.
  10. Now you have successfully removed the Hard drive.
    • Now you have successfully removed the Hard drive.
결론
Brian butler
회원 가입일: 2018년 10월 24일
97 평판
안내서 1개 작성함
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 17
전체 시간: 123
