주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Lenovo Thinkpad Helix Motherboard Replacement
필요한 것
  1. Lenovo Thinkpad Helix  Motherboard Replacement, Screen: 1 단계, 이미지 1개 중 1개
    • Using a plastic opening tool or opening pick, gently pry the screen off.
    • If possible, use plastic tools to pry the screen, as the metal tool as shown in the image can potentially damage your device.
    • You will need to use a little bit of force to pry it open. There is little indent that goes around the tablet. You will insert your tool between this indent and pry it open.
    • Once you're able to lift a little bit of the screen away from the tablet, work your way around until screen is separated from tablet. Stop for step two.
  2. Lenovo Thinkpad Helix  Motherboard Replacement: 2 단계, 이미지 3개 중 1개 Lenovo Thinkpad Helix  Motherboard Replacement: 2 단계, 이미지 3개 중 2개 Lenovo Thinkpad Helix  Motherboard Replacement: 2 단계, 이미지 3개 중 3개
    • Lift the screen up slowly.
    • Once separated, you can not fully take it off due to some cable connections.
    • Open the clips of the ZIF connectors and gently grab the cable to pull it out.
  3. Lenovo Thinkpad Helix  Motherboard Replacement: 3 단계, 이미지 1개 중 1개
    • Once the cables are disconnected, remove the screen.
  4. Lenovo Thinkpad Helix  Motherboard Replacement, Motherboard: 4 단계, 이미지 1개 중 1개
    • Remove the seven, 3mm, Phillips #00 screws attaching motherboard to the back cover.
  5. Lenovo Thinkpad Helix  Motherboard Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the white clips, then gently pull out both the motherboard and fan.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Aron Ndikumana
회원 가입일: 08/26/19
115 평판
안내서 1개를 작성함
Gateway, Team S1-G6, Saknee Fall 2019 Gateway, Team S1-G6, Saknee Fall 2019 회원
GCC-SAKNEE-F19S1G6
4 회원들
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 27
전체 시간: 1,444
