주요 콘텐츠로 건너뛰기
Lenovo Thinkpad T410i Keyboard Replacement
필요한 것
  1. Lenovo Thinkpad T410i Keyboard Replacement, Keyboard: 1 단계, 이미지 1/1
    • Remove the battery.
    • Unfortunately, the battery isn't pictured because our device did not come with a battery at the time of the creation of this guide.
  2. Lenovo Thinkpad T410i Keyboard Replacement: 2 단계, 이미지 1/2 Lenovo Thinkpad T410i Keyboard Replacement: 2 단계, 이미지 2/2
    • Loosen (do not remove) the 14.0mm screw in the DIMM slot cover with a Phillips #2 screwdriver.
  3. Lenovo Thinkpad T410i Keyboard Replacement: 3 단계, 이미지 1/1
    • Pry loose the top left key-covers with a plastic opening tool.
  4. Lenovo Thinkpad T410i Keyboard Replacement: 4 단계, 이미지 1/2 Lenovo Thinkpad T410i Keyboard Replacement: 4 단계, 이미지 2/2
    • Nudge the plastic tabs around the keyboard using the plastic opening tool while lifting it with a spudger.
    • Ensure all 5 clips are loosened from the front of the keyboard before removing.
  5. Lenovo Thinkpad T410i Keyboard Replacement: 5 단계, 이미지 1/1
    • Slowly raise keyboard away from the laptop. A short ribbon must be removed before keyboard is free.
    • Remove the keyboard from the device.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Gabriel Cordova
회원 가입일: 10/02/17
619 평판
안내서 4개 작성하였습니다
USF Tampa, Team S1-G2, Thompson Fall 2017 USF Tampa, Team S1-G2, Thompson Fall 2017 회원
USFT-THOMPSON-F17S1G2
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 17
전체 시간: 949
