주요 콘텐츠로 건너뛰기
Lenovo Thinkpad T410i LCD Screen Replacement
필요한 것
  1. Lenovo Thinkpad T410i LCD Screen Replacement, Screen Bezel: 1 단계, 이미지 1/2 Lenovo Thinkpad T410i LCD Screen Replacement, Screen Bezel: 1 단계, 이미지 2/2
    • Use a spudger to remove the plastic covers from the LCD screen.
  2. Lenovo Thinkpad T410i LCD Screen Replacement: 2 단계, 이미지 1/1
    • Remove the two 6.0mm screws on each side using Philips #0 head screwdriver as shown in the picture.
  3. Lenovo Thinkpad T410i LCD Screen Replacement: 3 단계, 이미지 1/1
    • Use a spudger to separate the bezel of the LCD screen.
  4. Lenovo Thinkpad T410i LCD Screen Replacement: 4 단계, 이미지 1/3 Lenovo Thinkpad T410i LCD Screen Replacement: 4 단계, 이미지 2/3 Lenovo Thinkpad T410i LCD Screen Replacement: 4 단계, 이미지 3/3
    • Continue along the edges lifting up and prying off the plastic LCD bezel.
  5. Lenovo Thinkpad T410i LCD Screen Replacement, LCD screen: 5 단계, 이미지 1/2 Lenovo Thinkpad T410i LCD Screen Replacement, LCD screen: 5 단계, 이미지 2/2
    • Use a Philips #0 head screwdriver to remove the two 6.0mm screws from the top corners of the LCD screen.
  6. Lenovo Thinkpad T410i LCD Screen Replacement: 6 단계, 이미지 1/3 Lenovo Thinkpad T410i LCD Screen Replacement: 6 단계, 이미지 2/3 Lenovo Thinkpad T410i LCD Screen Replacement: 6 단계, 이미지 3/3
    • Place the LCD screen safely down on its front.
    • Pulling the screen too far away from the screen may damage delicate ribbon cable.
    • Peel the tape off the ribbon cable's contacts.
    • Carefully detach the ribbon cable from the LCD screen.
    • Poking the golden contacts may easily damage them.
  7. Lenovo Thinkpad T410i LCD Screen Replacement: 7 단계, 이미지 1/1
    • Remove the screen from your device.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Harsh Patel
회원 가입일: 10/02/17
287 평판
안내서 2개 작성하였습니다
USF Tampa, Team S1-G2, Thompson Fall 2017 USF Tampa, Team S1-G2, Thompson Fall 2017 회원
USFT-THOMPSON-F17S1G2
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 11
전체 시간: 579
