주요 콘텐츠로 건너뛰기
Lenovo Thinkpad T410i Speakers Replacement
필요한 것
  1. Lenovo Thinkpad T410i Speakers Replacement, Keyboard: 1 단계, 이미지 1/1
    • Remove the battery.
    • Unfortunately, the battery isn't pictured because our device did not come with a battery at the time of the creation of this guide.
  2. Lenovo Thinkpad T410i Speakers Replacement: 2 단계, 이미지 1/2 Lenovo Thinkpad T410i Speakers Replacement: 2 단계, 이미지 2/2
    • Loosen (do not remove) the 14.0mm screw in the DIMM slot cover with a Phillips #2 screwdriver.
  3. Lenovo Thinkpad T410i Speakers Replacement: 3 단계, 이미지 1/1
    • Pry loose the top left key-covers with a plastic opening tool.
  4. Lenovo Thinkpad T410i Speakers Replacement: 4 단계, 이미지 1/2 Lenovo Thinkpad T410i Speakers Replacement: 4 단계, 이미지 2/2
    • Nudge the plastic tabs around the keyboard using the plastic opening tool while lifting it with a spudger.
    • Ensure all 5 clips are loosened from the front of the keyboard before removing.
  5. Lenovo Thinkpad T410i Speakers Replacement: 5 단계, 이미지 1/1
    • Slowly raise keyboard away from the laptop. A short ribbon must be removed before keyboard is free.
    • Remove the keyboard from the device.
  6. Lenovo Thinkpad T410i Speakers Replacement, Speakers: 6 단계, 이미지 1/1
    • Remove the six 14.0mm screws with a Phillips #0 screwdriver.
    • Remove the three 3.0mm screws with a Phillips #0 screwdriver.
  7. Lenovo Thinkpad T410i Speakers Replacement: 7 단계, 이미지 1/1
    • Snap off the top cover with a plastic opening tool, ensuring that the tabs don't snap back on.
  8. Lenovo Thinkpad T410i Speakers Replacement: 8 단계, 이미지 1/1
    • Lift the top panel off of the device.
    • Lift the panel slowly in order to not damage the orange ribbon cable.
  9. Lenovo Thinkpad T410i Speakers Replacement: 9 단계, 이미지 1/1
    • Detach the ribbon cable as shown in the picture.
  10. Lenovo Thinkpad T410i Speakers Replacement: 10 단계, 이미지 1/2 Lenovo Thinkpad T410i Speakers Replacement: 10 단계, 이미지 2/2
    • Remove the four 3.0mm screws with a Phillips #0 screwdriver.
  11. Lenovo Thinkpad T410i Speakers Replacement: 11 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Using the Precision Tweezers, remove the speaker cable from the connector.
    • Remove the speaker from the device.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Gabriel Cordova
회원 가입일: 10/02/17
619 평판
안내서 4개 작성하였습니다
USF Tampa, Team S1-G2, Thompson Fall 2017 USF Tampa, Team S1-G2, Thompson Fall 2017 회원
USFT-THOMPSON-F17S1G2
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 16
전체 시간: 1,379
