소개
This guide will teach you how to remove the built in speakers when they begin to fail or are entirely unresponsive.
Guide Notes
- The keyboard must be removed before the plastic top case can be removed.
- When separating the keyboard assembly from the laptop, be mindful of the unseen ribbon cable that must be disconnected.
- The touchpad, like the keyboard, has a ribbon cable that must be disconnected while raising the cover away from the body of the laptop.
필요한 것
Remove the six 14.0mm screws with a Phillips #0 screwdriver.
Remove the three 3.0mm screws with a Phillips #0 screwdriver.
거의 끝나갑니다!
결론
다른 4명이 해당 안내서를 완성하였습니다.
