소개
This guide will show the removal / replacement process for the webcam above the LCD if damaged.
Guide Notes
- You should only follow this guide after ruling out software issues from the list of problems and performing an exhaustive troubleshooting. Only replace your webcam if you are sure that the component is physically damaged. If your webcam stopped working after a liquid spillage or after crushing the webcam area, you may have to replace it.
- Please look up and try troubleshooting solutions to common webcam software problems, such as missing or outdated drivers, disabled webcam, etc.
- The webcam can be removed without first removing the LCD screen, although the screen is removed in this guide's pictures.
필요한 것
거의 끝나갑니다!
결론
다른 3명이 해당 안내서를 완성하였습니다.
