주요 콘텐츠로 건너뛰기
Lenovo Thinkpad T430 Hard drive or solid state drive replacement
필요한 것
  1. Lenovo Thinkpad T430 Hard drive or solid state drive replacement, Removing the battery and locating the drive enclousure: 1 단계, 이미지 1/1
    • Flip the laptop over.
    • Place it on a flat, sturdy surface.
    • Remove the battery by moving the battery latch and slowly sliding the battery out.
    • Locate the drive enclosure.
  2. Lenovo Thinkpad T430 Hard drive or solid state drive replacement, Removing the screw in the drive enclousure: 2 단계, 이미지 1/1
    • Use a small Phillips screwdriver to unscrew the single screw that holds down the drive enclosure cover.
    • The screw is designed to remain within the plastic cover. (This is called a captive screw.) Don't worry about extracting it completely.
  3. Lenovo Thinkpad T430 Hard drive or solid state drive replacement, Removing the drive enclosure: 3 단계, 이미지 1/1
    • Carefully remove the drive enclosure cover.
    • Be careful not break the small latches on the sides of the cover.
  4. Lenovo Thinkpad T430 Hard drive or solid state drive replacement, Pull out the pull tab: 4 단계, 이미지 1/1
    • Insert a spudger (or a similar tool) under the loop of the black pull tab, and gently pull it out from above the hard drive.
  5. Lenovo Thinkpad T430 Hard drive or solid state drive replacement: 5 단계, 이미지 1/1
    • Continue pulling on the pull tab until the hard drive and the two plastic rails come out of the enclosure.
    • Pull on the tab firmly but slowly. The hard drive should come out of the enclosure effortlessly.
  6. Lenovo Thinkpad T430 Hard drive or solid state drive replacement, Removing the rails from the drive: 6 단계, 이미지 1/1
    • Remove the plastic rails from the old drive and place them on the new drive.
결론
다른 37명이 해당 안내서를 완성하였습니다.
Michael Khmelnitsky
회원 가입일: 08/14/13
982 평판
안내서 1개 작성함
댓글 한 개
If the pull tab is not present - probably due to the drive being replaced - it is possible with care to put the tip of a screwdriver into the rubber side rails and pull the unit out
Tom Midgley - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 40
30일 전: 173
전체 시간: 66,157
