소개
Is your device turning off unexpectedly or not properly holding a charge? Consider using this guide to replace the battery in your device.
필요한 것
Make sure to power down and turn off your device before proceeding with the repair.
Flip your laptop over so that the backside is facing you.
Use the Phillips #1 screwdriver to remove the three screws holding in the battery.
다른 3명이 해당 안내서를 완성하였습니다.
