주요 콘텐츠로 건너뛰기
Lenovo Thinkpad T440s Display Replacement
필요한 것
  1. Lenovo Thinkpad T440s Display Replacement, Back Panel: 1 단계, 이미지 1/2 Lenovo Thinkpad T440s Display Replacement, Back Panel: 1 단계, 이미지 2/2
    • Make sure to power down and turn off your device before proceeding with the repair.
    • Flip your laptop over so that the backside is facing you.
  2. Lenovo Thinkpad T440s Display Replacement: 2 단계, 이미지 1/1
    • Using a Phillips #1 screwdriver, remove the eight screws securing the backplate.
    • Don’t try to force screws which won't come out. They are held in place by a stopper on the reverse side. This will not prevent you from removing the backplate.
  3. Lenovo Thinkpad T440s Display Replacement: 3 단계, 이미지 1/2 Lenovo Thinkpad T440s Display Replacement: 3 단계, 이미지 2/2
    • Using the metal spudger, wedge it in the seam where the backplate meets the front plate and run the tool along the seam to separate the backplate.
  4. Lenovo Thinkpad T440s Display Replacement: 4 단계, 이미지 1/1
    • Remove the back panel from the device.
  5. Lenovo Thinkpad T440s Display Replacement, Display: 5 단계, 이미지 1/3 Lenovo Thinkpad T440s Display Replacement, Display: 5 단계, 이미지 2/3 Lenovo Thinkpad T440s Display Replacement, Display: 5 단계, 이미지 3/3
    • Use the Phillips #1 screwdriver to remove the five screws securing the display mounts.
  6. Lenovo Thinkpad T440s Display Replacement: 6 단계, 이미지 1/3 Lenovo Thinkpad T440s Display Replacement: 6 단계, 이미지 2/3 Lenovo Thinkpad T440s Display Replacement: 6 단계, 이미지 3/3
    • Use the metal spudger to pry up the lever securing the ribbon cable in it's connection housing.
  7. Lenovo Thinkpad T440s Display Replacement: 7 단계, 이미지 1/3 Lenovo Thinkpad T440s Display Replacement: 7 단계, 이미지 2/3 Lenovo Thinkpad T440s Display Replacement: 7 단계, 이미지 3/3
    • Grab hold of the ribbon cable and pull it out of it's connection housing.
  8. Lenovo Thinkpad T440s Display Replacement: 8 단계, 이미지 1/2 Lenovo Thinkpad T440s Display Replacement: 8 단계, 이미지 2/2
    • Disconnect the white and blue wires connected to the mounted circuit by grabbing them close to the connection and pulling upward.
  9. Lenovo Thinkpad T440s Display Replacement: 9 단계, 이미지 1/2 Lenovo Thinkpad T440s Display Replacement: 9 단계, 이미지 2/2
    • Use the Phillips #1 screwdriver to remove the two screws securing the metal plate to expose the wire connection.
  10. Lenovo Thinkpad T440s Display Replacement: 10 단계, 이미지 1/2 Lenovo Thinkpad T440s Display Replacement: 10 단계, 이미지 2/2
    • Disconnect the wire by pulling it upward from the motherboard.
  11. Lenovo Thinkpad T440s Display Replacement: 11 단계, 이미지 1/3 Lenovo Thinkpad T440s Display Replacement: 11 단계, 이미지 2/3 Lenovo Thinkpad T440s Display Replacement: 11 단계, 이미지 3/3
    • Unclip the 5 wires connected to the display assembly from the motherboard and move them out of the way.
  12. Lenovo Thinkpad T440s Display Replacement: 12 단계, 이미지 1/3 Lenovo Thinkpad T440s Display Replacement: 12 단계, 이미지 2/3 Lenovo Thinkpad T440s Display Replacement: 12 단계, 이미지 3/3
    • Now that the display assembly is disconnected from the main body, lift both of the mounting brackets and remove the display assembly from the main body.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Terelle Montalvo
회원 가입일: 10/22/18
1,477 평판
안내서 8개 작성하였습니다
UMass Dartmouth, Team S1-G5, Simcock Fall 2018 UMass Dartmouth, Team S1-G5, Simcock Fall 2018 회원
UMASSD-SIMCOCK-F18S1G5
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 21
전체 시간: 3,267
