주요 콘텐츠로 건너뛰기
Lenovo Thinkpad T440s Hard Drive Replacement
필요한 것
  1. Lenovo Thinkpad T440s Hard Drive Replacement, Back Panel: 1 단계, 이미지 1/2 Lenovo Thinkpad T440s Hard Drive Replacement, Back Panel: 1 단계, 이미지 2/2
    • Make sure to power down and turn off your device before proceeding with the repair.
    • Flip your laptop over so that the backside is facing you.
  2. Lenovo Thinkpad T440s Hard Drive Replacement: 2 단계, 이미지 1/1
    • Using a Phillips #1 screwdriver, remove the eight screws securing the backplate.
    • Don’t try to force screws which won't come out. They are held in place by a stopper on the reverse side. This will not prevent you from removing the backplate.
  3. Lenovo Thinkpad T440s Hard Drive Replacement: 3 단계, 이미지 1/2 Lenovo Thinkpad T440s Hard Drive Replacement: 3 단계, 이미지 2/2
    • Using the metal spudger, wedge it in the seam where the backplate meets the front plate and run the tool along the seam to separate the backplate.
  4. Lenovo Thinkpad T440s Hard Drive Replacement: 4 단계, 이미지 1/1
    • Remove the back panel from the device.
  5. Lenovo Thinkpad T440s Hard Drive Replacement, Hard Drive: 5 단계, 이미지 1/2 Lenovo Thinkpad T440s Hard Drive Replacement, Hard Drive: 5 단계, 이미지 2/2
    • Use the Phillips #1 screwdriver to remove the single screw securing the hard drive.
  6. Lenovo Thinkpad T440s Hard Drive Replacement: 6 단계, 이미지 1/1
    • Use the metal spudger to lift the hard drive out of it's compartment.
  7. Lenovo Thinkpad T440s Hard Drive Replacement: 7 단계, 이미지 1/2 Lenovo Thinkpad T440s Hard Drive Replacement: 7 단계, 이미지 2/2
    • Grab a hold of the hard drive and pull it straight out from the device.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Terelle Montalvo
회원 가입일: 10/22/18
1,438 평판
안내서 8개 작성하였습니다
UMass Dartmouth, Team S1-G5, Simcock Fall 2018 UMass Dartmouth, Team S1-G5, Simcock Fall 2018 회원
UMASSD-SIMCOCK-F18S1G5
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 13
30일 전: 63
전체 시간: 9,107
