주요 콘텐츠로 건너뛰기
Lenovo Thinkpad T440s Keyboard Replacement
필요한 것
  1. Lenovo Thinkpad T440s Keyboard Replacement, Keyboard: 1 단계, 이미지 1/2 Lenovo Thinkpad T440s Keyboard Replacement, Keyboard: 1 단계, 이미지 2/2
    • Start with the laptop open and the keyboard exposed.
  2. Lenovo Thinkpad T440s Keyboard Replacement: 2 단계, 이미지 1/3 Lenovo Thinkpad T440s Keyboard Replacement: 2 단계, 이미지 2/3 Lenovo Thinkpad T440s Keyboard Replacement: 2 단계, 이미지 3/3
    • Use the metal spudger to press the keyboard plate forward towards the display
  3. Lenovo Thinkpad T440s Keyboard Replacement: 3 단계, 이미지 1/1
    • Use a Phillips #00 screwdrivers to remove the six screws holding in the keyboard.
  4. Lenovo Thinkpad T440s Keyboard Replacement: 4 단계, 이미지 1/3 Lenovo Thinkpad T440s Keyboard Replacement: 4 단계, 이미지 2/3 Lenovo Thinkpad T440s Keyboard Replacement: 4 단계, 이미지 3/3
    • Use the metal spudger to lift up the keyboard plate.
    • Run the metal spudger around the plate, applying light pressure until the keyboard pops out.
  5. Lenovo Thinkpad T440s Keyboard Replacement: 5 단계, 이미지 1/3 Lenovo Thinkpad T440s Keyboard Replacement: 5 단계, 이미지 2/3 Lenovo Thinkpad T440s Keyboard Replacement: 5 단계, 이미지 3/3
    • The keyboard can now be rested forward to expose the ribbon cable attaching it to the motherboard.
    • The ribbon cable will come out with a light pull in the opposite direction of its connection.
    • The keyboard is now removed and ready to be replaced.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Terelle Montalvo
회원 가입일: 10/22/18
1,477 평판
안내서 8개 작성하였습니다
UMass Dartmouth, Team S1-G5, Simcock Fall 2018 UMass Dartmouth, Team S1-G5, Simcock Fall 2018 회원
UMASSD-SIMCOCK-F18S1G5
3 회원들
안내서 8개 작성하였습니다
댓글 한 개
how can i get a video for guideline?
Taiye Phisical - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 12
30일 전: 79
전체 시간: 5,398
