소개
Is your device experiencing problems with loading and saving while the computer is in use? Consider using this guide to replace the RAM in your device.
필요한 것
Make sure to power down and turn off your device before proceeding with the repair.
Flip your laptop over so that the backside is facing you.
다른 7명이 해당 안내서를 완성하였습니다.
댓글 한 개
I have a T460, very similar. A few points missing here… It’s imperative to take out the battery first. Most other tutorials mention disabling the internal battery in the BIOS before starting the process. Then screws don’t come out, they stay attached, which is very nice but better if you expect it. And one of them is right under the battery. The 460 has 2 memory slots, and they’re both functional. I had to swap my 4G card to the second slot, and put the 8G one in to replace it, I don’t know whether that’s mandatory or it was just bad seating initially.
