주요 콘텐츠로 건너뛰기
Lenovo Thinkpad T450 CMOS Battery Replacement
필요한 것
  1. Lenovo Thinkpad T450 CMOS Battery Replacement, External Battery: 1 단계, 이미지 1/3 Lenovo Thinkpad T450 CMOS Battery Replacement, External Battery: 1 단계, 이미지 2/3 Lenovo Thinkpad T450 CMOS Battery Replacement, External Battery: 1 단계, 이미지 3/3
    • Using your hands, slide the two locking tabs away from each other to release the battery.
    • Slide the battery up and out of the device.
  2. Lenovo Thinkpad T450 CMOS Battery Replacement, Back Cover: 2 단계, 이미지 1/1
    • Using the JIS #00 screwdriver, unscrew seven screws from the back cover.
    • These screws are not removable and will remain in the back cover.
    • Use the JIS #00 screwdriver to remove the single 2.8 mm screw from the back cover.
  3. Lenovo Thinkpad T450 CMOS Battery Replacement: 3 단계, 이미지 1/3 Lenovo Thinkpad T450 CMOS Battery Replacement: 3 단계, 이미지 2/3 Lenovo Thinkpad T450 CMOS Battery Replacement: 3 단계, 이미지 3/3
    • Insert a plastic opening tool into the edges of the laptop and work your way around the edges to pry off the back cover from the device.
    • Remove the back cover from the device.
  4. Lenovo Thinkpad T450 CMOS Battery Replacement, CMOS Battery: 4 단계, 이미지 1/3 Lenovo Thinkpad T450 CMOS Battery Replacement, CMOS Battery: 4 단계, 이미지 2/3 Lenovo Thinkpad T450 CMOS Battery Replacement, CMOS Battery: 4 단계, 이미지 3/3
    • Using the plastic opening tool, disconnect the CMOS battery from the motherboard.
  5. Lenovo Thinkpad T450 CMOS Battery Replacement: 5 단계, 이미지 1/2 Lenovo Thinkpad T450 CMOS Battery Replacement: 5 단계, 이미지 2/2
    • Insert the plastic opening tool underneath the CMOS battery and pry it up and away from the motherboard.
    • When you reassemble your device, you may need to reapply adhesive to the back of the CMOS battery.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Justin Ogihara
회원 가입일: 09/18/17
27,794 평판
안내서 52개 작성하였습니다
EDU Team EDU Team 회원
Staff
7 회원들
안내서 678개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 7
7일 전: 63
30일 전: 295
전체 시간: 10,072
