주요 콘텐츠로 건너뛰기
Lenovo Thinkpad T450 RAM Replacement
필요한 것
  1. Lenovo Thinkpad T450 RAM Replacement, External Battery: 1 단계, 이미지 1/3 Lenovo Thinkpad T450 RAM Replacement, External Battery: 1 단계, 이미지 2/3 Lenovo Thinkpad T450 RAM Replacement, External Battery: 1 단계, 이미지 3/3
    • Using your hands, slide the two locking tabs away from each other to release the battery.
    • Slide the battery up and out of the device.
  2. Lenovo Thinkpad T450 RAM Replacement, Back Cover: 2 단계, 이미지 1/1
    • Using the JIS #00 screwdriver, unscrew seven screws from the back cover.
    • These screws are not removable and will remain in the back cover.
    • Use the JIS #00 screwdriver to remove the single 2.8 mm screw from the back cover.
  3. Lenovo Thinkpad T450 RAM Replacement: 3 단계, 이미지 1/3 Lenovo Thinkpad T450 RAM Replacement: 3 단계, 이미지 2/3 Lenovo Thinkpad T450 RAM Replacement: 3 단계, 이미지 3/3
    • Insert a plastic opening tool into the edges of the laptop and work your way around the edges to pry off the back cover from the device.
    • Remove the back cover from the device.
  4. Lenovo Thinkpad T450 RAM Replacement, RAM: 4 단계, 이미지 1/2 Lenovo Thinkpad T450 RAM Replacement, RAM: 4 단계, 이미지 2/2
    • Lift up the black piece of tape and remove it to uncover the RAM sticks underneath.
  5. Lenovo Thinkpad T450 RAM Replacement: 5 단계, 이미지 1/2 Lenovo Thinkpad T450 RAM Replacement: 5 단계, 이미지 2/2
    • Using your fingers, push the two clips securing the RAM away from each other to release the RAM.
    • The RAM stick should pop up at a 30 degree angle.
    • Remove the RAM stick from the device.
    • Repeat this step for any additional RAM sticks.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Justin Ogihara
회원 가입일: 09/18/17
27,167 평판
안내서 52개 작성하였습니다
EDU Team EDU Team 회원
Staff
7 회원들
안내서 637개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 17
30일 전: 78
전체 시간: 2,083
