주요 콘텐츠로 건너뛰기
Lenovo Thinkpad T450s Bottom Panel Removal
필요한 것
  1. Lenovo Thinkpad T450s Bottom Panel Removal, Battery: 1 단계, 이미지 1/2 Lenovo Thinkpad T450s Bottom Panel Removal, Battery: 1 단계, 이미지 2/2
    • Turn off device before starting
    • Flip the laptop upside down so you have access to the battery.
  2. Lenovo Thinkpad T450s Bottom Panel Removal: 2 단계, 이미지 1/1
    • Slide lock button 1 to the unlock position and gently slide away from your body.
  3. Lenovo Thinkpad T450s Bottom Panel Removal: 3 단계, 이미지 1/2 Lenovo Thinkpad T450s Bottom Panel Removal: 3 단계, 이미지 2/2
    • Slide lock button 2 to the unlock position and continue gently sliding until the battery is removed.
  4. Lenovo Thinkpad T450s Bottom Panel Removal, Lenovo Thinkpad T450s Bottom Panel Removal: 4 단계, 이미지 1/3 Lenovo Thinkpad T450s Bottom Panel Removal, Lenovo Thinkpad T450s Bottom Panel Removal: 4 단계, 이미지 2/3 Lenovo Thinkpad T450s Bottom Panel Removal, Lenovo Thinkpad T450s Bottom Panel Removal: 4 단계, 이미지 3/3
    • Flip the device over and lay it down with the underside facing upwards.
    • Unscrew all 8 screws. While they should not come out completely, in some cases, the plastic retaining washers may come off of one or more of the screws, allowing them to come out completely. - should this happen, look for a loose, tiny black plastic washer once the case is open. It's possible, in some cases, to reattach the retaining washer.
  5. Lenovo Thinkpad T450s Bottom Panel Removal: 5 단계, 이미지 1/2 Lenovo Thinkpad T450s Bottom Panel Removal: 5 단계, 이미지 2/2
    • Pry the bottom from the computer until it pops out.
    • In some cases, the vented side of the case may cling to the heat sink; appears to be adhesive. Take care when separating.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Hayden Hausman
회원 가입일: 01/17/19
625 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 30
전체 시간: 3,686
