주요 콘텐츠로 건너뛰기
Lenovo Thinkpad T450s Fan Replacement
필요한 것
  1. Lenovo Thinkpad T450s Fan Replacement, Fan: 1 단계, 이미지 1/1
    • Flip the laptop over so that the bottom is facing up.
    • Unlock the battery by sliding the keys outwards. When unlocked, push the battery forwards to remove.
  2. Lenovo Thinkpad T450s Fan Replacement: 2 단계, 이미지 1/1
    • Unscrew all 3.7 mm Phillips #0 screws from the back of the laptop. Half of them will remain attached to the cover.
    • Lift off the back cover.
  3. Lenovo Thinkpad T450s Fan Replacement: 3 단계, 이미지 1/1
    • Unscrew the four 5 mm Phillips #0 screws that secure the heatsink.
    • The screws will remain attached.
    • The Fan is attached to the heat sink assembly.
  4. Lenovo Thinkpad T450s Fan Replacement: 4 단계, 이미지 1/1
    • Use a plastic opening tool or a nylon spudger to push the fan's bundled cable connector free.
    • Remove the fan and heat sink assembly from the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Murphy Derwent
회원 가입일: 04/05/22
130 평판
안내서 1개 작성함
IUPUI, Team 2-3, Harley Spring 2022 IUPUI, Team 2-3, Harley Spring 2022 회원
IUPUI-HARLEY-S22S2G3
3 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 26
전체 시간: 1,327
