주요 콘텐츠로 건너뛰기
Lenovo Thinkpad T450s Keyboard Replacement
필요한 것
  1. Lenovo Thinkpad T450s Keyboard Replacement, Keyboard: 1 단계, 이미지 1/1
    • Remove the battery by pulling on the two sliding buttons next to the battery.
  2. Lenovo Thinkpad T450s Keyboard Replacement: 2 단계, 이미지 1/2 Lenovo Thinkpad T450s Keyboard Replacement: 2 단계, 이미지 2/2
    • Remove the seven 5mm screws on the back cover using the Phillips #0 screwdriver.
  3. Lenovo Thinkpad T450s Keyboard Replacement: 3 단계, 이미지 1/1
    • Remove the two rubber stoppers from where the battery previously was.
  4. Lenovo Thinkpad T450s Keyboard Replacement: 4 단계, 이미지 1/2 Lenovo Thinkpad T450s Keyboard Replacement: 4 단계, 이미지 2/2
    • Flip the laptop, shift the keyboard upwards by applying force to the two indents on the keyboard.
    • Remove the six 5mm screws that are on the keyboard using the Phillips #0 screwdriver.
    • These screws are located above the left ctrl key, S, F, J, semicolon, and up arrow keys.
  5. Lenovo Thinkpad T450s Keyboard Replacement: 5 단계, 이미지 1/1
    • Lift the keyboard and flip over exposing the connection to the motherboard.
  6. Lenovo Thinkpad T450s Keyboard Replacement: 6 단계, 이미지 1/1
    • Remove the plastic covering and detach touch point and keyboard cable.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Nathan Morgan
회원 가입일: 11/11/19
469 평판
안내서 2개 작성하였습니다
IUPUI, Team S2-G5, Stella Fall 2019 IUPUI, Team S2-G5, Stella Fall 2019 회원
IUPUI-STELLA-F19S2G5
3 회원들
안내서 2개 작성하였습니다
댓글 한 개
If after replacement your keyboard has some keys clacking, make sure you slid the keyboard all the way back. Even a small amount can make some keys feel weird.
Ivan Veloz - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 29
30일 전: 105
전체 시간: 6,106
