주요 콘텐츠로 건너뛰기
Lenovo Thinkpad T450s Motherboard Replacement
필요한 것
  1. Lenovo Thinkpad T450s Motherboard Replacement, Fan: 1 단계, 이미지 1/1
    • Flip the laptop over so that the bottom is facing up.
    • Unlock the battery by sliding the keys outwards. When unlocked, push the battery forwards to remove.
  2. Lenovo Thinkpad T450s Motherboard Replacement: 2 단계, 이미지 1/1
    • Unscrew all 3.7 mm Phillips #0 screws from the back of the laptop. Half of them will remain attached to the cover.
    • Lift off the back cover.
  3. Lenovo Thinkpad T450s Motherboard Replacement: 3 단계, 이미지 1/1
    • Unscrew the four 5 mm Phillips #0 screws that secure the heatsink.
    • The screws will remain attached.
    • The Fan is attached to the heat sink assembly.
  4. Lenovo Thinkpad T450s Motherboard Replacement: 4 단계, 이미지 1/1
    • Use a plastic opening tool or a nylon spudger to push the fan's bundled cable connector free.
    • Remove the fan and heat sink assembly from the motherboard.
  5. Lenovo Thinkpad T450s Motherboard Replacement, Motherboard: 5 단계, 이미지 1/1
    • Remove all twelve 3.6 mm Phillips #00 screws.
  6. Lenovo Thinkpad T450s Motherboard Replacement, Remove the Hard Drive: 6 단계, 이미지 1/2 Lenovo Thinkpad T450s Motherboard Replacement, Remove the Hard Drive: 6 단계, 이미지 2/2
    • Remove the hard drive from the motherboard's by gently pulling it out and up at the same time.
  7. Lenovo Thinkpad T450s Motherboard Replacement: 7 단계, 이미지 1/1
    • Pull out the socket that is attached to the left side of the battery case.
  8. Lenovo Thinkpad T450s Motherboard Replacement: 8 단계, 이미지 1/1
    • Unplug the cable that attaches the polymer battery to the motherboard by pulling it out carefully.
  9. Lenovo Thinkpad T450s Motherboard Replacement: 9 단계, 이미지 1/1
    • Remove the ribbon cable attached to the the battery case carefully by pulling the cable up and out.
  10. Lenovo Thinkpad T450s Motherboard Replacement: 10 단계, 이미지 1/1
    • Remove the motherboard from the case. If the motherboard does not come off the case or feels stuck, make sure that you have removed all the cables prior
결론
다른 2명이 해당 안내서를 완성하였습니다.
Sara Karimi Razakani
회원 가입일: 03/31/22
178 평판
안내서 1개 작성함
IUPUI, Team 2-3, Harley Spring 2022 IUPUI, Team 2-3, Harley Spring 2022 회원
IUPUI-HARLEY-S22S2G3
3 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 9
30일 전: 42
전체 시간: 1,308
