주요 콘텐츠로 건너뛰기
Lenovo Thinkpad T450s Network Adapter Card Replacement
필요한 것
  1. Lenovo Thinkpad T450s Network Adapter Card Replacement, Battery: 1 단계, 이미지 1/2 Lenovo Thinkpad T450s Network Adapter Card Replacement, Battery: 1 단계, 이미지 2/2
    • Turn off device before starting
    • Flip the laptop upside down so you have access to the battery.
  2. Lenovo Thinkpad T450s Network Adapter Card Replacement: 2 단계, 이미지 1/1
    • Slide lock button 1 to the unlock position and gently slide away from your body.
  3. Lenovo Thinkpad T450s Network Adapter Card Replacement: 3 단계, 이미지 1/2 Lenovo Thinkpad T450s Network Adapter Card Replacement: 3 단계, 이미지 2/2
    • Slide lock button 2 to the unlock position and continue gently sliding until the battery is removed.
  4. Lenovo Thinkpad T450s Network Adapter Card Replacement, Lenovo Thinkpad T450s Bottom Panel Removal: 4 단계, 이미지 1/3 Lenovo Thinkpad T450s Network Adapter Card Replacement, Lenovo Thinkpad T450s Bottom Panel Removal: 4 단계, 이미지 2/3 Lenovo Thinkpad T450s Network Adapter Card Replacement, Lenovo Thinkpad T450s Bottom Panel Removal: 4 단계, 이미지 3/3
    • Flip the device over and lay it down with the underside facing upwards.
    • Unscrew all 8 screws. While they should not come out completely, in some cases, the plastic retaining washers may come off of one or more of the screws, allowing them to come out completely. - should this happen, look for a loose, tiny black plastic washer once the case is open. It's possible, in some cases, to reattach the retaining washer.
  5. Lenovo Thinkpad T450s Network Adapter Card Replacement: 5 단계, 이미지 1/2 Lenovo Thinkpad T450s Network Adapter Card Replacement: 5 단계, 이미지 2/2
    • Pry the bottom from the computer until it pops out.
    • In some cases, the vented side of the case may cling to the heat sink; appears to be adhesive. Take care when separating.
  6. Lenovo Thinkpad T450s Network Adapter Card Replacement, Network Adapter Card: 6 단계, 이미지 1/2 Lenovo Thinkpad T450s Network Adapter Card Replacement, Network Adapter Card: 6 단계, 이미지 2/2
    • Remove the single 3mm screw holding the network adapter in place.
    • You will have to locate and lift up a small, black area of film covering the screw and network adapter.
  7. Lenovo Thinkpad T450s Network Adapter Card Replacement: 7 단계, 이미지 1/1
    • Remove the two cables connected (1 black, 1 grey) from the network adapter.
    • The cables will pop off once the screw is removed.
  8. Lenovo Thinkpad T450s Network Adapter Card Replacement: 8 단계, 이미지 1/1
    • Pull the network adapter out of the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Hayden Hausman
회원 가입일: 01/17/19
625 평판
안내서 6개 작성하였습니다
댓글 한 개
You neglected something important in step 1. The t450s has 2 batteries, 1 removable and another built in. To do repair work you MUST first reboot to the bios setup and disable the built-in battery in addition to removing the outboard battery.
Also you neglect to mention that the radio adapter has a dual function, wifi and bluetooth; also the bios has a whitelist of acceptable radio cards and it can be difficult to find a replacement.
Also, the screws holding the bottom casing on are phillips head and are screwed into soft plastic, some of the heads being deeply recessed. A phillips head screwdriver will not seat on the head without at least a bit of pressure, so the last turn or two with the screw almost out cannot take the screw out, instead it’s just forced back into the plastic. And with a deep recess, it’s VERY hard to pull the screw out completely.
robtahopkins - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 18
전체 시간: 1,918
