부품
부품은 필요하지 않습니다.
  1. Remove the button with the arrow pointing left.
    • Remove the button with the arrow pointing left.
    • You can do this by putting your fingernail or a Spudger underneath the button and pulling up.
  2. Remove these two 10mm screws with a Phillips head screwdriver using the #00 bit.
    • Remove these two 10mm screws with a Phillips head screwdriver using the #00 bit.
    • Use a plastic Spudger to pry open and disconnect the screen from the rest of the tablet.
      • Be gentle and work from the bottom of the tablet counterclockwise.
    • Open the tablet screen to the left. Making sure not to disconnect any of the wires connecting the screen and tablet.
    • Peel back the rubber tape strip from the battery.
    • To peel back the ribbon connectors first gently open the white gates.
    • You can do this with a plastic Spudger or your fingernail.
    • After you have opened the white gates just simply pull out the ribbon connectors.
    • Peel them back so they are not sticking to the battery.
    • Remove the four 5mm screws that I am pointing to with the metal tools.
    • Use a Phillips head screwdriver using the #00 bit.
    • Disconnect this connector I am pointing to.
    • Remove it gently with your fingers pulling towards the battery.
    • Simply remove the old battery carefully.
결론
Michael Gaskey
회원 가입일: 2018년 09월 28일
337 평판
안내서 2개 작성하였습니다
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 42
전체 시간: 95
