주요 콘텐츠로 건너뛰기
Lenovo Thinkpad Tablet 1838 Button Replacement
필요한 것
  1. Lenovo Thinkpad Tablet 1838 Button Replacement, Button: 1 단계, 이미지 1/1
    • Remove the button on the front of the tablet that has the arrow pointing to the left .
    • You can do this by putting your fingernail or a Spudger underneath the button and pulling up.
  2. Lenovo Thinkpad Tablet 1838 Button Replacement: 2 단계, 이미지 1/1
    • Remove the 2 screws found under the button you just removed with a size #00 Philips Head Screwdriver.
  3. Lenovo Thinkpad Tablet 1838 Button Replacement: 3 단계, 이미지 1/1
    • Use a plastic spudger to pry open the screen from the tablet.
    • Work around the perimeter of the tablet going counter-clockwise.
  4. Lenovo Thinkpad Tablet 1838 Button Replacement: 4 단계, 이미지 1/1
    • Open the tablet screen to the left. (Like opening a book) Making sure not to disconnect any of the wires connecting the screen and tablet.
  5. Lenovo Thinkpad Tablet 1838 Button Replacement: 5 단계, 이미지 1/1
    • To peel back the ribbon connector, first gently open the white gates.
    • You can do this with a plastic Spudger or your fingernail.
  6. Lenovo Thinkpad Tablet 1838 Button Replacement: 6 단계, 이미지 1/1
    • Remove the screw that is highlighted.
    • Use a size #00 Philips head screwdriver.
  7. Lenovo Thinkpad Tablet 1838 Button Replacement: 7 단계, 이미지 1/1
    • Remove the blue motherboard the screw was attached to.
    • Make sure to remove it carefully, so you do not accidentally damage the surrounding parts.
  8. Lenovo Thinkpad Tablet 1838 Button Replacement: 8 단계, 이미지 1/3 Lenovo Thinkpad Tablet 1838 Button Replacement: 8 단계, 이미지 2/3 Lenovo Thinkpad Tablet 1838 Button Replacement: 8 단계, 이미지 3/3
    • To remove the buttons, you need to push the little black tabs towards each other with either your fingernails or plastic spudger.
    • While the tabs are pushed in the buttons should pop out.
결론
Dylan Coleman
회원 가입일: 09/21/18
157 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 16
전체 시간: 356
