주요 콘텐츠로 건너뛰기
Lenovo Thinkpad Tablet 1838 Speaker Replacement
필요한 것
  1. Lenovo Thinkpad Tablet 1838 Speaker Replacement, Speaker: 1 단계, 이미지 1개 중 1개
    • Remove the middle button by putting a plastic spudger or your fingernail underneath the button and lifting up.
  2. Lenovo Thinkpad Tablet 1838 Speaker Replacement: 2 단계, 이미지 1개 중 1개
    • There will be two screws under the button you have removed. Use your Phillips #00 Screwdriver to remove these screws.
  3. Lenovo Thinkpad Tablet 1838 Speaker Replacement: 3 단계, 이미지 1개 중 1개
    • With a plastic spudger or your fingernail, find the seam where the front and back panel connect and pry open from the bottom. After making a small opening, go around the device counter-clockwise.
  4. Lenovo Thinkpad Tablet 1838 Speaker Replacement: 4 단계, 이미지 1개 중 1개
    • Before you separate the panels, there is a ribbon cable connecting the LCD to the motherboard. To avoid damage of the ribbon cable, lift the panel with the LCD from right to left like opening a book.
  5. Lenovo Thinkpad Tablet 1838 Speaker Replacement: 5 단계, 이미지 2개 중 1개 Lenovo Thinkpad Tablet 1838 Speaker Replacement: 5 단계, 이미지 2개 중 2개
    • This is the speaker unit, and is being held by a screw. Use a Phillips #00 Screwdriver to remove the screw indicated by the red circle in the second image.
  6. Lenovo Thinkpad Tablet 1838 Speaker Replacement: 6 단계, 이미지 2개 중 1개 Lenovo Thinkpad Tablet 1838 Speaker Replacement: 6 단계, 이미지 2개 중 2개
    • The speaker is still connected to the motherboard by a little connector. Using a plastic spudger or your fingernail, pry the connector to the direction marked by the two red arrows in the second image.
  7. Lenovo Thinkpad Tablet 1838 Speaker Replacement: 7 단계, 이미지 1개 중 1개
    • After removing the connector, you can now remove the speaker. Use your spudger or fingernail to lift the speaker up. The speaker should come out easily.
결론
작성자
2다른 기여자 명과 함께
Arturo Barboza
회원 가입일: 10/26/17
209 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 177
