주요 콘텐츠로 건너뛰기
Lenovo Thinkpad Tablet 1838 Touch Screen Replacement
필요한 것
  1. Lenovo Thinkpad Tablet 1838 Touch Screen Replacement, Touch Screen: 1 단계, 이미지 1/1
    • Remove the button with the arrow pointing left.
    • You can do this by putting the spudger underneath the button and pulling up.
  2. Lenovo Thinkpad Tablet 1838 Touch Screen Replacement: 2 단계, 이미지 1/1
    • Remove the two 10mm Phillips #00 screws.
  3. Lenovo Thinkpad Tablet 1838 Touch Screen Replacement: 3 단계, 이미지 1/1
    • Use an opening tool to pry open and disconnect the screen from the rest of the tablet.
    • Be gentle and work from the bottom of the tablet in counterclockwise direction.
  4. Lenovo Thinkpad Tablet 1838 Touch Screen Replacement: 4 단계, 이미지 1/1
    • Open the tablet screen to the left, making sure not to disconnect any of the wires connecting the screen to the tablet.
  5. Lenovo Thinkpad Tablet 1838 Touch Screen Replacement: 5 단계, 이미지 1/2 Lenovo Thinkpad Tablet 1838 Touch Screen Replacement: 5 단계, 이미지 2/2
    • Disconnect the ribbon connector by pulling up on the white gate.
    • Then just simply pull the wire to the left to disconnect it.
  6. Lenovo Thinkpad Tablet 1838 Touch Screen Replacement: 6 단계, 이미지 1/2 Lenovo Thinkpad Tablet 1838 Touch Screen Replacement: 6 단계, 이미지 2/2
    • Disconnect the last ribbon connector using your fingernails to grip the ends of the connector and gently pull to the left.
    • There might be some tape over the connector that you will have to remove.
  7. Lenovo Thinkpad Tablet 1838 Touch Screen Replacement: 7 단계, 이미지 1/1
    • You have successfully removed the old screen.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Michael Gaskey
회원 가입일: 09/28/18
355 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 16
전체 시간: 756
