주요 콘텐츠로 건너뛰기
Lenovo Thinkpad Twist s230u Battery Replacement
필요한 것
  1. Lenovo Thinkpad Twist s230u Battery Replacement, Hard Drive: 1 단계, 이미지 1/2 Lenovo Thinkpad Twist s230u Battery Replacement, Hard Drive: 1 단계, 이미지 2/2
    • Flip the laptop over.
    • Using a Phillips #1 Screwdriver, unscrew the screw on the bottom left corner.
  2. Lenovo Thinkpad Twist s230u Battery Replacement: 2 단계, 이미지 1/1
    • Using the iFixit Opening tool, loosen the hard drive cover.
  3. Lenovo Thinkpad Twist s230u Battery Replacement: 3 단계, 이미지 1/1
    • Remove the hard drive cover.
  4. Lenovo Thinkpad Twist s230u Battery Replacement: 4 단계, 이미지 1/2 Lenovo Thinkpad Twist s230u Battery Replacement: 4 단계, 이미지 2/2
    • Remove the hard drive by sliding it out.
  5. Lenovo Thinkpad Twist s230u Battery Replacement, Keyboard: 5 단계, 이미지 1/1
    • Use a Philips #1 screwdriver to remove 2 screws on the bottom of the laptop.
  6. Lenovo Thinkpad Twist s230u Battery Replacement: 6 단계, 이미지 1/1
    • Use a spudger to loosen the keyboard around the edges.
    • Carefully push the keyboard towards the screen to unlatch it.
    • Do not push too hard, as there are ribbon cables attached to the keyboard.
  7. Lenovo Thinkpad Twist s230u Battery Replacement: 7 단계, 이미지 1/1
    • Carefully lift up the keyboard to access the wires underneath.
    • Be careful not to break the ribbon cables attached underneath.
  8. Lenovo Thinkpad Twist s230u Battery Replacement: 8 단계, 이미지 1/3 Lenovo Thinkpad Twist s230u Battery Replacement: 8 단계, 이미지 2/3 Lenovo Thinkpad Twist s230u Battery Replacement: 8 단계, 이미지 3/3
    • Open the small black flap on each of the ribbon cables. It should lift with a slight effort.
    • Pull out the ribbon cables and remove the keyboard from the device.
  9. Lenovo Thinkpad Twist s230u Battery Replacement, Upper Casing: 9 단계, 이미지 1/1
    • Flip your device over.
    • Use the Phillips #1 screwdriver to remove the nine screws.
  10. Lenovo Thinkpad Twist s230u Battery Replacement: 10 단계, 이미지 1/2 Lenovo Thinkpad Twist s230u Battery Replacement: 10 단계, 이미지 2/2
    • Flip the device back over and open the top.
    • Use the Phillips #1 screwdriver to remove the seven silver screws.
    • Disconnect the three cables inside the case.
    • Lift up the brown tab and disconnect the ribbon cable.
  11. Lenovo Thinkpad Twist s230u Battery Replacement: 11 단계, 이미지 1/2 Lenovo Thinkpad Twist s230u Battery Replacement: 11 단계, 이미지 2/2
    • Close the lid and turn the device around.
    • Use the iFixit Opening Tool to lift up and remove the tab on the back.
  12. Lenovo Thinkpad Twist s230u Battery Replacement: 12 단계, 이미지 1/2 Lenovo Thinkpad Twist s230u Battery Replacement: 12 단계, 이미지 2/2
    • Turn the device back around and reopen it.
    • Use the iFixit Opening Tool to disconnect the top of the case from the bottom.
    • Lift up the top of the case and slide it out from under the screen.
  13. Lenovo Thinkpad Twist s230u Battery Replacement, Battery: 13 단계, 이미지 1/2 Lenovo Thinkpad Twist s230u Battery Replacement, Battery: 13 단계, 이미지 2/2
    • Remove the single silver screw using the Phillips #1 screwdriver.
  14. Lenovo Thinkpad Twist s230u Battery Replacement: 14 단계, 이미지 1/1
    • Unplug the colored cables.
  15. Lenovo Thinkpad Twist s230u Battery Replacement: 15 단계, 이미지 1/1
    • Lift the battery out of the laptop.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Arthur McPeak
회원 가입일: 01/14/20
691 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 16
30일 전: 67
전체 시간: 4,423
