소개
This guide will help you remove the upper casing from your Lenovo Thinkpad Twist s230u. The upper casing covers the inside of the laptop, making it look nicer and keeping important components from being damaged or broken. Although you will probably never need to replace the upper casing itself, it must be removed in order to perform most other replacements. If, however, you do want to replace it, or you simply need to remove it for another replacement, this guide is for you.
필요한 것
Flip the laptop over.
Using a Phillips #1 Screwdriver, unscrew the screw on the bottom left corner.
Flip your device over.
Use the Phillips #1 screwdriver to remove the nine screws.
다른 한 분이 해당 안내서를 완성하였습니다.
