주요 콘텐츠로 건너뛰기
Lenovo Thinkpad X1 Carbon 4th Gen Bottom Panel Replacement
필요한 것
  1. Lenovo Thinkpad X1 Carbon 4th Gen Bottom Panel Replacement, Bottom Panel: 1 단계, 이미지 1/2 Lenovo Thinkpad X1 Carbon 4th Gen Bottom Panel Replacement, Bottom Panel: 1 단계, 이미지 2/2
    • Unscrew the nine captive screws on the bottom cover of the laptop using a Phillips #1 screwdriver.
    • The screws do not fully come out of the back cover, so there is no need for screw management.
    • There are a few small clips around the edge that you may need to pry at to free them. An opening pick may be helpful for this process.
  2. Lenovo Thinkpad X1 Carbon 4th Gen Bottom Panel Replacement: 2 단계, 이미지 1/1
    • Lift the back cover up and off of the computer.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Alexander Davis
회원 가입일: 01/23/20
1,093 평판
안내서 7개 작성하였습니다
Cal Poly, Team S1-G4, White Winter 2020 Cal Poly, Team S1-G4, White Winter 2020 회원
CPSU-WHITE-W20S1G4
3 회원들
안내서 19개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 13
30일 전: 37
전체 시간: 1,610
