주요 콘텐츠로 건너뛰기
Lenovo Thinkpad X1 Carbon 4th Gen Fan Replacement
필요한 것
  1. Lenovo Thinkpad X1 Carbon 4th Gen Fan Replacement, Bottom Panel: 1 단계, 이미지 2개 중 1개 Lenovo Thinkpad X1 Carbon 4th Gen Fan Replacement, Bottom Panel: 1 단계, 이미지 2개 중 2개
    • Unscrew the nine captive screws on the bottom cover of the laptop using a Phillips #1 screwdriver.
    • The screws do not fully come out of the back cover, so there is no need for screw management.
    • There are a few small clips around the edge that you may need to pry at to free them. An opening pick may be helpful for this process.
  2. Lenovo Thinkpad X1 Carbon 4th Gen Fan Replacement: 2 단계, 이미지 1개 중 1개
    • Lift the back cover up and off of the computer.
  3. Lenovo Thinkpad X1 Carbon 4th Gen Fan Replacement, Cooling Fan: 3 단계, 이미지 2개 중 1개 Lenovo Thinkpad X1 Carbon 4th Gen Fan Replacement, Cooling Fan: 3 단계, 이미지 2개 중 2개
    • Peel off the black protective film to the left of the fan.
  4. Lenovo Thinkpad X1 Carbon 4th Gen Fan Replacement: 4 단계, 이미지 3개 중 1개 Lenovo Thinkpad X1 Carbon 4th Gen Fan Replacement: 4 단계, 이미지 3개 중 2개 Lenovo Thinkpad X1 Carbon 4th Gen Fan Replacement: 4 단계, 이미지 3개 중 3개
    • Do not remove the four screws closest to the fan. They do not affect the fan assembly.
    • Disconnect the antenna wires on green the wireless LAN card to the left of the fan.
  5. Lenovo Thinkpad X1 Carbon 4th Gen Fan Replacement: 5 단계, 이미지 3개 중 1개 Lenovo Thinkpad X1 Carbon 4th Gen Fan Replacement: 5 단계, 이미지 3개 중 2개 Lenovo Thinkpad X1 Carbon 4th Gen Fan Replacement: 5 단계, 이미지 3개 중 3개
    • Lift up the hinge connector that is attached to the fan's ribbon cable.
    • Carefully disconnect the cable by pulling outwards from the ribbon connector.
  6. Lenovo Thinkpad X1 Carbon 4th Gen Fan Replacement: 6 단계, 이미지 3개 중 1개 Lenovo Thinkpad X1 Carbon 4th Gen Fan Replacement: 6 단계, 이미지 3개 중 2개 Lenovo Thinkpad X1 Carbon 4th Gen Fan Replacement: 6 단계, 이미지 3개 중 3개
    • Loosen the screws on the 'x' configuration of metal.
    • These screws are held on to the metal 'x', so don't worry about them falling out.
  7. Lenovo Thinkpad X1 Carbon 4th Gen Fan Replacement: 7 단계, 이미지 1개 중 1개
    • Lift the fan upwards from the board.
  8. Lenovo Thinkpad X1 Carbon 4th Gen Fan Replacement: 8 단계, 이미지 1개 중 1개
    • It's best practice to replace the old thermal paste under the 'x' configuration of metal. (Guides on how to replace thermal paste can be found here.)
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Alexander Davis
회원 가입일: 01/23/20
1,213 평판
안내서 7개를 작성함
Cal Poly, Team S1-G4, White Winter 2020 Cal Poly, Team S1-G4, White Winter 2020 회원
CPSU-WHITE-W20S1G4
3 회원들
안내서 21개를 작성함
2가이드 댓글
I bought a refurbished Lenovo from Ebay and it purports to be a Carbon X1 4th Gen, but its guts do not look like the ones depicted in the photo. Instead, it looks like https://davidmintz.org/images/20210703_l.... Nevertheless I was able to remove the fan — the general idea is similar enough. After three or so years this machine has died with a simple “Fan error” message at boot time. I tried blowing out some dust and trying again, no luck. So I will be looking for the replacement part. Wish me luck. Thank you for the guide!
David Mintz - 답글
Very useful and allowed me to clean the fan on my 4th gen X1 Carbon. That fixed the immediate "fan error" message on boot failure. It is running rough so I will have to replace it soon I think.
Edwin Blake - 답글
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 26
지난 30일: 108
전체 시간: 8,576
