주요 콘텐츠로 건너뛰기
Lenovo Thinkpad X1 Carbon 4th Gen Fingerprint Press Scanner Replacement
필요한 것
  1. Lenovo Thinkpad X1 Carbon 4th Gen Fingerprint Press Scanner Replacement, Bottom Panel: 1 단계, 이미지 1/2 Lenovo Thinkpad X1 Carbon 4th Gen Fingerprint Press Scanner Replacement, Bottom Panel: 1 단계, 이미지 2/2
    • Unscrew the nine captive screws on the bottom cover of the laptop using a Phillips #1 screwdriver.
    • The screws do not fully come out of the back cover, so there is no need for screw management.
    • There are a few small clips around the edge that you may need to pry at to free them. An opening pick may be helpful for this process.
  2. Lenovo Thinkpad X1 Carbon 4th Gen Fingerprint Press Scanner Replacement: 2 단계, 이미지 1/1
    • Lift the back cover up and off of the computer.
  3. Lenovo Thinkpad X1 Carbon 4th Gen Fingerprint Press Scanner Replacement, Speakers: 3 단계, 이미지 1/3 Lenovo Thinkpad X1 Carbon 4th Gen Fingerprint Press Scanner Replacement, Speakers: 3 단계, 이미지 2/3 Lenovo Thinkpad X1 Carbon 4th Gen Fingerprint Press Scanner Replacement, Speakers: 3 단계, 이미지 3/3
    • Carefully unplug the speaker connector by pulling it towards you.
  4. Lenovo Thinkpad X1 Carbon 4th Gen Fingerprint Press Scanner Replacement: 4 단계, 이미지 1/2 Lenovo Thinkpad X1 Carbon 4th Gen Fingerprint Press Scanner Replacement: 4 단계, 이미지 2/2
    • Remove the two 5 mm screws on each speaker with a Phillips #1 screwdriver.
  5. Lenovo Thinkpad X1 Carbon 4th Gen Fingerprint Press Scanner Replacement: 5 단계, 이미지 1/2 Lenovo Thinkpad X1 Carbon 4th Gen Fingerprint Press Scanner Replacement: 5 단계, 이미지 2/2
    • Unweave the blue and white wires from underneath the plastic tabs connected to the battery.
  6. Lenovo Thinkpad X1 Carbon 4th Gen Fingerprint Press Scanner Replacement: 6 단계, 이미지 1/1
    • Lift each speaker up and out from the computer.
  7. Lenovo Thinkpad X1 Carbon 4th Gen Fingerprint Press Scanner Replacement, Lithium Battery: 7 단계, 이미지 1/3 Lenovo Thinkpad X1 Carbon 4th Gen Fingerprint Press Scanner Replacement, Lithium Battery: 7 단계, 이미지 2/3 Lenovo Thinkpad X1 Carbon 4th Gen Fingerprint Press Scanner Replacement, Lithium Battery: 7 단계, 이미지 3/3
    • Carefully lift the far end of the battery connector with an opening tool facing towards you.
    • Remove the connector by pushing it forward and lifting.
  8. Lenovo Thinkpad X1 Carbon 4th Gen Fingerprint Press Scanner Replacement: 8 단계, 이미지 1/2 Lenovo Thinkpad X1 Carbon 4th Gen Fingerprint Press Scanner Replacement: 8 단계, 이미지 2/2
    • Remove the central 5 mm screw with a Phillips #1 screwdriver.
  9. Lenovo Thinkpad X1 Carbon 4th Gen Fingerprint Press Scanner Replacement: 9 단계, 이미지 1/1
    • Lift the battery up and out of the computer.
  10. Lenovo Thinkpad X1 Carbon 4th Gen Fingerprint Press Scanner Replacement, Fingerprint Press Scanner: 10 단계, 이미지 1/2 Lenovo Thinkpad X1 Carbon 4th Gen Fingerprint Press Scanner Replacement, Fingerprint Press Scanner: 10 단계, 이미지 2/2
    • Lift the black hinge that is on top of the ribbon connector using the iFixit pick.
  11. Lenovo Thinkpad X1 Carbon 4th Gen Fingerprint Press Scanner Replacement: 11 단계, 이미지 1/2 Lenovo Thinkpad X1 Carbon 4th Gen Fingerprint Press Scanner Replacement: 11 단계, 이미지 2/2
    • Lift the purple ribbon connector up and out.
    • There are small plastic tabs that prevent the ribbon connector from being pulled horizontally out.
  12. Lenovo Thinkpad X1 Carbon 4th Gen Fingerprint Press Scanner Replacement: 12 단계, 이미지 1/1
    • Remove the two 2.5 mm black screws on the fingerprint scanner with a Phillips #1 screwdriver.
  13. Lenovo Thinkpad X1 Carbon 4th Gen Fingerprint Press Scanner Replacement: 13 단계, 이미지 1/3 Lenovo Thinkpad X1 Carbon 4th Gen Fingerprint Press Scanner Replacement: 13 단계, 이미지 2/3 Lenovo Thinkpad X1 Carbon 4th Gen Fingerprint Press Scanner Replacement: 13 단계, 이미지 3/3
    • Gently lift the right edge up of the fingerprint scanner up and slide the scanner to the right before lifting.
결론
Alexander Davis
회원 가입일: 01/23/20
1,114 평판
안내서 7개 작성하였습니다
Cal Poly, Team S1-G4, White Winter 2020 Cal Poly, Team S1-G4, White Winter 2020 회원
CPSU-WHITE-W20S1G4
3 회원들
안내서 19개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 23
전체 시간: 1,839
