소개
This guide will take you through how to replace the keyboard in your Lenovo ThinkPad X201 Tablet if it is broken or damaged.
부품
부품은 필요하지 않습니다.
  1. First you push the lock button on the back of the computer from lock to unlock.
    • First you push the lock button on the back of the computer from lock to unlock.
  2. Then you hold it on unlocked and slide the battery pack out.
    • Then you hold it on unlocked and slide the battery pack out.
  3. US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  4. Using a Phillips #00 screwdriver unscrew the four screws in the back of the laptop that have a keyboard symbol next to them. Using a Phillips #00 screwdriver unscrew the four screws in the back of the laptop that have a keyboard symbol next to them. Using a Phillips #00 screwdriver unscrew the four screws in the back of the laptop that have a keyboard symbol next to them.
    • Using a Phillips #00 screwdriver unscrew the four screws in the back of the laptop that have a keyboard symbol next to them.
  5. Using your fingers push keyboard forward so it is closer to the screen than it was before
    • Using your fingers push keyboard forward so it is closer to the screen than it was before
  6. Use a flathead screwdriver to gently lift up on the keyboard until it comes off. Make sure you disconnect the ribbon cable from the motherboard before removing the KB completely.
    • Use a flathead screwdriver to gently lift up on the keyboard until it comes off. Make sure you disconnect the ribbon cable from the motherboard before removing the KB completely.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Thomas Donahue
회원 가입일: 2018년 03월 20일
458 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S5-G7, Peak Spring 2018 UMass Dartmouth, Team S5-G7, Peak Spring 2018 회원
UMASSD-PEAK-S18S5G7
3 회원들
안내서 12개 작성하였습니다
Excellent.. thank you.. I just put on my new keyboard. I appreciated seeing your photos just to make sure I didn’t miss anything.
Andy - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 12
지난 30일: 58
전체 시간: 511
