주요 콘텐츠로 건너뛰기
Lenovo Thinkpad X201 Tablet Keyboard Replacement
필요한 것
  1. Lenovo Thinkpad X201 Tablet Keyboard Replacement, Battery: 1 단계, 이미지 1/1
    • First you push the lock button on the back of the computer from lock to unlock.
  2. Lenovo Thinkpad X201 Tablet Keyboard Replacement: 2 단계, 이미지 1/1
    • Then you hold it on unlocked and slide the battery pack out.
  3. Lenovo Thinkpad X201 Tablet Keyboard Replacement, Keyboard: 3 단계, 이미지 1/3 Lenovo Thinkpad X201 Tablet Keyboard Replacement, Keyboard: 3 단계, 이미지 2/3 Lenovo Thinkpad X201 Tablet Keyboard Replacement, Keyboard: 3 단계, 이미지 3/3
    • Using a Phillips #00 screwdriver unscrew the four screws in the back of the laptop that have a keyboard symbol next to them.
  4. Lenovo Thinkpad X201 Tablet Keyboard Replacement: 4 단계, 이미지 1/1
    • Using your fingers push keyboard forward so it is closer to the screen than it was before
  5. Lenovo Thinkpad X201 Tablet Keyboard Replacement: 5 단계, 이미지 1/1
    • Use a flathead screwdriver to gently lift up on the keyboard until it comes off. Make sure you disconnect the ribbon cable from the motherboard before removing the KB completely.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Thomas Donahue
회원 가입일: 03/20/18
474 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S5-G7, Peak Spring 2018 UMass Dartmouth, Team S5-G7, Peak Spring 2018 회원
UMASSD-PEAK-S18S5G7
3 회원들
안내서 12개 작성하였습니다
댓글 한 개
Excellent.. thank you.. I just put on my new keyboard. I appreciated seeing your photos just to make sure I didn’t miss anything.
Andy - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 14
전체 시간: 2,384
