주요 콘텐츠로 건너뛰기
Lenovo Thinkpad X201 Tablet LCD Replacement
필요한 것
  1. Lenovo Thinkpad X201 Tablet LCD Replacement, LCD: 1 단계, 이미지 1/1
    • First you push the lock button on the back of the computer from lock to unlock
  2. Lenovo Thinkpad X201 Tablet LCD Replacement: 2 단계, 이미지 1/1
    • Then you hold it on unlocked and slide the battery pack out
  3. Lenovo Thinkpad X201 Tablet LCD Replacement: 3 단계, 이미지 1/3 Lenovo Thinkpad X201 Tablet LCD Replacement: 3 단계, 이미지 2/3 Lenovo Thinkpad X201 Tablet LCD Replacement: 3 단계, 이미지 3/3
    • remove all screw covers above hinges
  4. Lenovo Thinkpad X201 Tablet LCD Replacement: 4 단계, 이미지 1/2 Lenovo Thinkpad X201 Tablet LCD Replacement: 4 단계, 이미지 2/2
    • Unscrew the screws on the front of the LCD screen
  5. Lenovo Thinkpad X201 Tablet LCD Replacement: 5 단계, 이미지 1/2 Lenovo Thinkpad X201 Tablet LCD Replacement: 5 단계, 이미지 2/2
    • Remove additional two screws near bezel screws plus the single logic board screw in the center
  6. Lenovo Thinkpad X201 Tablet LCD Replacement: 6 단계, 이미지 1/3 Lenovo Thinkpad X201 Tablet LCD Replacement: 6 단계, 이미지 2/3 Lenovo Thinkpad X201 Tablet LCD Replacement: 6 단계, 이미지 3/3
    • Gently pry the LCD cover with a flat head screwdriver, and pivot it over the signal cable near the LCD hinges. Pivot over all four corners
  7. Lenovo Thinkpad X201 Tablet LCD Replacement: 7 단계, 이미지 1/2 Lenovo Thinkpad X201 Tablet LCD Replacement: 7 단계, 이미지 2/2
    • Continue to remove screens in front of the LCD cover, make sure all screws in the front are removed
  8. Lenovo Thinkpad X201 Tablet LCD Replacement: 8 단계, 이미지 1/1
    • Once all screws are removed, remove the LCD Display but gently peeling back line a sticker
결론
다른 2명이 해당 안내서를 완성하였습니다.
Peter Gachuki
회원 가입일: 03/26/18
642 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team S5-G7, Peak Spring 2018 UMass Dartmouth, Team S5-G7, Peak Spring 2018 회원
UMASSD-PEAK-S18S5G7
3 회원들
안내서 12개 작성하였습니다
댓글 한 개
Is there any other screen that can be used?
Darren Lewis - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 43
전체 시간: 3,167
