주요 콘텐츠로 건너뛰기
Lenovo Thinkpad X220 Keyboard Replacement
필요한 것
  1. Lenovo Thinkpad X220 Keyboard Replacement, Battery: 1 단계, 이미지 1/3 Lenovo Thinkpad X220 Keyboard Replacement, Battery: 1 단계, 이미지 2/3 Lenovo Thinkpad X220 Keyboard Replacement, Battery: 1 단계, 이미지 3/3
    • Locate the two switches that lock the battery.
    • Then push the left switch outward into the "unlocked" position.
    • This switch will remain in the unlocked position.
  2. Lenovo Thinkpad X220 Keyboard Replacement: 2 단계, 이미지 1/2 Lenovo Thinkpad X220 Keyboard Replacement: 2 단계, 이미지 2/2
    • Now push and hold the right switch to the right while using the other hand to gently slide the battery upwards out of the laptop.
  3. Lenovo Thinkpad X220 Keyboard Replacement: 3 단계, 이미지 1/2 Lenovo Thinkpad X220 Keyboard Replacement: 3 단계, 이미지 2/2
    • This is a rechargeable Li-Ion battery that has a capacity of 4400 mAh, if you have the 6 cell model.
    • The 4 or 9 cell model has different ratings.
  4. Lenovo Thinkpad X220 Keyboard Replacement, Keyboard: 4 단계, 이미지 1/1
    • Put the laptop upside down.
    • Unscrew the two keyboard retention screws.
  5. Lenovo Thinkpad X220 Keyboard Replacement: 5 단계, 이미지 1/2 Lenovo Thinkpad X220 Keyboard Replacement: 5 단계, 이미지 2/2
    • Put the laptop back on its feet, open the lid and push the keyboard from the TrackPoint click buttons.
    • After that, pull it from the laptop assembly.
  6. Lenovo Thinkpad X220 Keyboard Replacement: 6 단계, 이미지 1/2 Lenovo Thinkpad X220 Keyboard Replacement: 6 단계, 이미지 2/2
    • You should now have access to the keyboard's connector.
    • Pull it gently from the grabbing tip.
  7. Lenovo Thinkpad X220 Keyboard Replacement: 7 단계, 이미지 1/1
    • The keyboard is now totally unplugged from the laptop.
    • Here you go! Plug a new keyboard on the connector and follow the steps in the reverse order to finish your repair.
결승점
다른 9명이 해당 안내서를 완성하였습니다.
alphaLONE
회원 가입일: 07/01/11
927 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 8
30일 전: 58
전체 시간: 6,032
