주요 콘텐츠로 건너뛰기
Lenovo Thinkpad X220 Keyboard Replacement
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
  1. Lenovo Thinkpad X220 Keyboard Replacement, Battery: 1 단계, 이미지 1/3 Lenovo Thinkpad X220 Keyboard Replacement, Battery: 1 단계, 이미지 2/3 Lenovo Thinkpad X220 Keyboard Replacement, Battery: 1 단계, 이미지 3/3
    • Locate the two switches that lock the battery.
    • Then push the left switch outward into the "unlocked" position.
    • This switch will remain in the unlocked position.
  2. Lenovo Thinkpad X220 Keyboard Replacement: 2 단계, 이미지 1/2 Lenovo Thinkpad X220 Keyboard Replacement: 2 단계, 이미지 2/2
    • Now push and hold the right switch to the right while using the other hand to gently slide the battery upwards out of the laptop.
  3. Lenovo Thinkpad X220 Keyboard Replacement: 3 단계, 이미지 1/2 Lenovo Thinkpad X220 Keyboard Replacement: 3 단계, 이미지 2/2
    • This is a rechargeable Li-Ion battery that has a capacity of 4400 mAh, if you have the 6 cell model.
    • The 4 or 9 cell model has different ratings.
  4. Lenovo Thinkpad X220 Keyboard Replacement, Keyboard: 4 단계, 이미지 1/1
    • Remove the two J00 screws on the backside.
  5. Lenovo Thinkpad X220 Keyboard Replacement: 5 단계, 이미지 1/1
    • Remove the plate next to the battery.
    • Remove the side panel.
  6. Lenovo Thinkpad X220 Keyboard Replacement: 6 단계, 이미지 1/1
    • Close laptop.
    • Flip laptop over so battery side is facing down.
    • The screen needs to be open when separating the keyboard and trackpad from the base.
  7. Lenovo Thinkpad X220 Keyboard Replacement: 7 단계, 이미지 1/3 Lenovo Thinkpad X220 Keyboard Replacement: 7 단계, 이미지 2/3 Lenovo Thinkpad X220 Keyboard Replacement: 7 단계, 이미지 3/3
    • Using the Metal Spudger, place between the trackpad and the keyboard and lift up to remove the keyboard and trackpad.
    • Pull keyboard towards yourself.
    • Grab the tab on the ribbon wire, pull off to release the keyboard.
    • Pull keyboard towards yourself exposing the ribbon wire that attaches it.
    • Grab the tab on the ribbon wire and pull up to release.
  8. Lenovo Thinkpad X220 Keyboard Replacement: 8 단계, 이미지 1/1
    • Grab new keyboard and clamp the ribbon into place.
    • Gently push the sides of keyboard into place.
    • Keyboard is now replaced and ready for use.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Mariska Gramlow
회원 가입일: 01/06/16
893 평판
안내서 5개 작성하였습니다
댓글 2개
you're removing way too many screws, you're actually unscrewing the palmrest and some of the motherboard with the keyboard.
alphaLONE - 답글
this is an absolutely awful guide...do not unscrew all those screws and do NOT use a metal spludger unless you want chips of plastic flying everywhere.
Jesus.
Nice Volcano - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 2,590
