주요 콘텐츠로 건너뛰기
Lenovo Thinkpad X220 Trackpad Replacement
필요한 것
  1. Lenovo Thinkpad X220 Trackpad Replacement, Trackpad: 1 단계, 이미지 1/1
    • Turn laptop over to expose the battery.
    • Slide and unlock the sliders while removing the battery casing at the same.
    • Place battery in a safe spot.
  2. Lenovo Thinkpad X220 Trackpad Replacement: 2 단계, 이미지 1/1
    • Grab the Phillips screwdriver with the JIS, J00 head.
    • Remove all screws on the backside where the battery was removed.
    • You should have 10 screws total.
    • Place the 10 screws in a safe spot.
  3. Lenovo Thinkpad X220 Trackpad Replacement: 3 단계, 이미지 1/1
    • Remove the plate next to the battery.
    • Remove the side panel.
  4. Lenovo Thinkpad X220 Trackpad Replacement: 4 단계, 이미지 1/3 Lenovo Thinkpad X220 Trackpad Replacement: 4 단계, 이미지 2/3 Lenovo Thinkpad X220 Trackpad Replacement: 4 단계, 이미지 3/3
    • Close laptop.
    • Flip laptop over to battery side is facing down.
    • The screen needs to be open when separating the keyboard and trackpad from the base.
    • Using the Metal Spudger, place between the trackpad and the keyboard and lift up to remove.
    • Pull keyboard towards yourself.
    • Grab the tab on the ribbon wire, pull off to release the keyboard.
  5. Lenovo Thinkpad X220 Trackpad Replacement: 5 단계, 이미지 1/3 Lenovo Thinkpad X220 Trackpad Replacement: 5 단계, 이미지 2/3 Lenovo Thinkpad X220 Trackpad Replacement: 5 단계, 이미지 3/3
    • Now, you can get to the trackpad ribbon wire.
    • The trackpad ribbon wire in blue, unhinge the clamp to release the blue ribbon wire.
    • Get a hold of the trackpad and pull up and out of the laptop.
    • Carefully slide new trackpad into the hinges.
    • With the keyboard, clamp the ribbon back into place.
    • Slide replacement keyboard in.
    • Press the sides of the keyboard to secure placement.
    • New trackpad is now ready to be used, make sure it is in place and secure.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Mariska Gramlow
회원 가입일: 01/06/16
893 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 37
전체 시간: 5,701
