주요 콘텐츠로 건너뛰기
Lenovo Thinkpad X240 RAM Replacement
필요한 것
  1. Lenovo Thinkpad X240 RAM Replacement, RAM: 1 단계, 이미지 1/1
    • Flip the laptop up side down as shown in the photo.
  2. Lenovo Thinkpad X240 RAM Replacement: 2 단계, 이미지 1/2 Lenovo Thinkpad X240 RAM Replacement: 2 단계, 이미지 2/2
    • Remove the 8 0.2mm Phillips screws connecting the back cover to the laptop.
  3. Lenovo Thinkpad X240 RAM Replacement: 3 단계, 이미지 1/1
    • Remove the back cover using the opening tools.
    • Gently use the plastic opening tools to prevent scratching your device.
  4. Lenovo Thinkpad X240 RAM Replacement: 4 단계, 이미지 1/2 Lenovo Thinkpad X240 RAM Replacement: 4 단계, 이미지 2/2
    • Remove the RAM stick by carefully popping its holders out of place.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Joe Edmondson
회원 가입일: 09/20/17
326 평판
안내서 1개 작성함
댓글 2개
Does this Thinkpad really have only one RAM slot? Or is there another one on the back of the board (i.e. under the keyboard)?
Sebastian Swirski - 답글
Would I be able to add a 16gb ram stick in it? Even though the highest spec config that the laptop ships with is only 8gb?
Mahir Max - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 36
전체 시간: 4,739
