이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
필요한 것
동영상 개요
Flip the computer upside down.
The red rectangle shows the location of the battery.
Locate the two switches that lock the battery. Push the left-hand switch outward into the "unlocked" position.
Now push and hold the right clip to the right while using your other hand to gently slide the battery away from the computer.
Locate the hard drive enclosure (marked by the red rectangle).
Use a small Phillips screwdriver to unscrew the single screw that holds down the hard drive enclosure cover.
Carefully remove the hard drive enclosure cover.
Gently pull the black pull tab out from above the hard drive. Continue pulling on the pull tab until the hard drive and the two plastic rails come out of the enclosure.
Remove the plastic rails from the old SSD/hard drive and place them on the new SSD/hard drive.
다른 21명이 해당 안내서를 완성하였습니다.
댓글 15개
Hy sir
i have one question about this laptop lenovo x230 thinkpad i have internald SSD 128 i want to increase in 500GB any body can tell me
which size of ssd possible for lenovo think pad x230 and which company thanks
It looks to be a 2.5 in hard drive/solid state drive.
Hi,
I have an lenovo thinkpad x230t convertible laptop, which I want to upgrade with a ssd what are the specifications I should be looking for in a ssd so that it would be compatible with my laptop,
Thanks in advance
