주요 콘텐츠로 건너뛰기
Lenovo Thinkpad x240 Internal Battery Replacement
필요한 것
  1. Lenovo Thinkpad x240 Internal Battery  Replacement, Internal Battery: 1 단계, 이미지 1개 중 1개
    • Turn off the laptop.
    • Device's lights should all be off.
  2. Lenovo Thinkpad x240 Internal Battery  Replacement: 2 단계, 이미지 2개 중 1개 Lenovo Thinkpad x240 Internal Battery  Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the back cover by unscrewing the 8 0.2 mm screws holding it in place.
  3. Lenovo Thinkpad x240 Internal Battery  Replacement: 3 단계, 이미지 2개 중 1개 Lenovo Thinkpad x240 Internal Battery  Replacement: 3 단계, 이미지 2개 중 2개
    • Locate the internal battery pack and unscrew the 3 0.2 mm screws holding it in place.
  4. Lenovo Thinkpad x240 Internal Battery  Replacement: 4 단계, 이미지 2개 중 1개 Lenovo Thinkpad x240 Internal Battery  Replacement: 4 단계, 이미지 2개 중 2개
    • Unplug the connector cable that connects the internal battery pack to the laptop.
  5. Lenovo Thinkpad x240 Internal Battery  Replacement: 5 단계, 이미지 1개 중 1개
    • Insert the new internal battery pack into the laptop.
결론
다른 8명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Mohammed Alsaadi
회원 가입일: 09/20/17
621 평판
안내서 2개를 작성함
2가이드 댓글
“0.2 mm screws”? There is no such thing as 0.2mm screws! I can only assume that you’ve meant to write M2 screws though since you messed that up I’m wondering if it’s really M2 screws or if it could be M2.5 or even M3 screws instead.
This is crucial information to all those people who only have a battery dummy in their original configuration needing to figure out what screws to buy to secure the new actual internal battery inside the case.
eiion - 답글
Two supply the missing information: According to the Maintenance Manual they are three M2x4mm.
eiion - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 12
지난 30일: 92
전체 시간: 17,996
